Show us your home-brew combat designs.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> Show us your home-brew combat designs.
Page: [1] 2 3   next >   >>
Login
Show us your home-brew combat designs. - 2/14/2004 10:12:23 PM
WolverineRC
Status: offline
Post pictures of your home-brew combat aircraft. let's see what you are flying.
This is my .25 size Komet.
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Show us your home-brew combat designs. - 2/15/2004 12:09:14 AM
Demon
Status: offline
Woo boy, this thread should get quite a bit of play since so many of us brew our own!
Below are a a few of mine. The Hellcat is 1/12th + 10% with an Irvine .25 in the nose. The Hurricane is 1/12th + 5% with an OS.25FX in the nose. The SPADs are my own concoction called "Slayers" based on the Derilict/Dogfighter with 5/8" tall oak spars in all 2mm wings with taped-on 4mm ailerons.
Next?
D
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Demon -- 2/15/2004 12:11:50 AM >
_____________________________
Darin Bellis
RCCA 426
(in reply to WolverineRC)
       Post #: 2
RE: Show us your home-brew combat designs. - 2/15/2004 4:12:02 AM
thojo
Status: offline
Here's my Sidewinder. Made with 3/4" alum rail from Home Depot...
Click for fullsize
(in reply to Demon)
       Post #: 3
RE: Show us your home-brew combat designs. - 2/15/2004 2:55:41 PM
gunfighter
Status: offline
Here are a couple of my "Flat Smack's"
(in reply to thojo)
       Post #: 4
RE: Show us your home-brew combat designs. - 2/15/2004 4:56:19 PM
WolverineRC
Status: offline
Nice stuff guys. here are a few more of mine.
The first I call a GremFloy, Gremlin wing with a Battle Floyd type fuse.
Next is a Small flying wing version of a QHOR, it was a little heavy for the wing area.
My Faltcat was an experiment using 1/2" coro for a profile fuse.
Last my 82"Ws B-2 With an OS 46 on it (not Exactly a combat plane)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to gunfighter)
       Post #: 5
RE: Show us your home-brew combat designs. - 2/15/2004 11:13:23 PM
jnaarnold
Status: offline
Here's mine, might be a bit big for combat, but thats what I plan to do with her.....
Click for fullsize
Click for fullsize
       Post #: 6
RE: Show us your home-brew combat designs. - 2/16/2004 12:17:06 AM
rrh
Status: offline
SSC - maple stick fuse, coro wing w/ yardstick spar
Open B - maple and alum fuses, coro wings w/ screen door frame spars
rrh
(in reply to jnaarnold)
       Post #: 7
RE: Show us your home-brew combat designs. - 2/16/2004 1:43:34 AM
combatpigg
Status: offline
HEY WOLVERINE! Nice looking B2! Have you flown any combat with it yet? Here's a look at my BEAUTIFUL 1/2A jobs! I'll throw in a shot of my SSC too, just to strike fear in everyones' heart !
Click for fullsize
Click for fullsize
Led Zeppelin is NOT "old fogie" music.
       Post #: 8
RE: Show us your home-brew combat designs. - 2/16/2004 1:23:16 PM
WolverineRC
Status: offline
Here is my latest combat ship, Code name Wolverine, its still under development. I have two like it and started the third with a few new ideas.
Click for fullsize
(in reply to combatpigg)
       Post #: 9
RE: Show us your home-brew combat designs. - 2/16/2004 3:13:33 PM
aseaholm
Status: offline
Long before I was approached to produce kits, the AVENGER was a home brew machine. It started out with Lexan and Foam from Home Depot, Coro and Basswood from Hobby Lobby, and spruce and spring steel from my local hobby store.
Then a combat buddy stumbled on to G10 at a local scrap yard and away we went.
The first AVENGER I build was done with a borrowed foam bow, a battery charger, and a dremel tool. They weren’t pretty but eventually they worked.
Fortunately, I have a great girl that gets power tools for me on special occasions. The scroll saw and belt sander sure make life a lot easier.
I’ve put together a history on the evolution of my design here:
http://www.teamseaholm.com/rccombat/evolution.htm
This may be helpful for folks setting out to design a new killer combat machine. I’ve made a lot of mistakes along the way and tried lots of things that didn’t work. Perhaps, you can learn from those mistakes. This should make getting to a great flying machine a shorter process.
A.J. Seaholm
www.teamseaholm.com
HOME of the AVENGER
seaholm@teamseaholm.com
Here’s a pic of my AVENGERs at a local contest last season.
Click for fullsize
< Message edited by THE TICK -- 2/16/2004 3:20:10 PM >
       Post #: 10
RE: Show us your home-brew combat designs. - 2/17/2004 8:02:54 PM
Montague
Status: offline
My A and SSC clas Rapier:
Build instructions are online at www.midatlanticcombat.com
No good pictures, but my B ships are Skull Bandit fuses with my own wing on them right now.
For scale, I'm working on a cool ship, but it's not at the picture-taking stage yet.
Kirk Montague Adams
RCCA 560
(in reply to aseaholm)
       Post #: 11
RE: Show us your home-brew combat designs. - 2/18/2004 2:38:06 AM
Joe Ortiz
Status: offline
Gunfighter, what's your setup on your Smack, I have a Smack 2 wing needing a new fuse, I have a flat bat available, I need measurements, how does it fly with a .15??. As for everybody else, nice looking planes.
Joe
(in reply to Montague)
       Post #: 12
RE: Show us your home-brew combat designs. - 2/21/2004 12:15:07 AM
gunfighter
Status: offline
Joe - I use an all flying tail on mine. The fuse is 19" from front of bat (firewall) to the hinge point on the elevator. It's VERY short coupled! I use a bladder inside the fuse placed in a plastic sleeve used for carrying golf clubs. Full size (64" smack wing, all blue foam with 3 - 1/8" fiberglass rods for spars. 3 - Hitec 311 servo's and 750 MaH NiMh AAA pack. LA .15 up front. Right at 41 - 42 oz.
VERY fast! Very close to the falcon with a bladder, but the flying tail does make it pretty touchy on the elevator. CG = 3 1/2" from LE.
Hope this helps!
(in reply to Joe Ortiz)
       Post #: 13
RE: Show us your home-brew combat designs. - 2/22/2004 12:58:14 AM
WolverineRC
Status: offline
Here is the latest Version of the Wolverine, Went for tip fins, Profile fuse strapped to the wing with rubber bands to allow some give but not break on a hard hit, Tested the theory today and it works well. Also trying a bladder tank, not sure its worth the hassle.
Click for fullsize
