RE: SPA3DEFI-PROFILE-Flight Report & Pics
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> RE: SPA3DEFI-PROFILE-Flight Report & Pics
Page: <<   < prev  1 2 3 [4]
Login
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/2/2004 6:19:31 PM
SDR-Hammer
Status: offline
Novabill, I’m in the process of building a plane similar to your design, just need to get to the LHS for parts to finish. In the process I cut new tail feathers, borrowing your design using counter balance controls, for my QHOR. I flew it the other day and the counter balances on the elevator failed, folding back, breaking the bamboo skewers used for strengthening measures.
Just curious what you have done to prevent this?
Also can you post those pics and the Cad you mentioned?
(in reply to novabill)
       Post #: 76
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/3/2004 1:16:01 PM
novabill
Status: offline
quote:
ORIGINAL: SDR-Hammer
I will try to find the disk that had the photos of when I redid the fuse. I dont know what to say about the counterbalances I have never had one fail. Were you flying at 100 mph? Is your coro 4mm? some 4mm is not as strong as others, I have a bunch of yellow that is soft and more like 3mm. I have flown mine verry fast at times and never had one bend, especially with the bamboo. I cant get my cad drawings to download, but I can fax the stab to you if you want. Each half has a 10"span the LE has no taper, the root cord is 9" and the tip cord is 6". Then, you hinge it 3" back from the LE and make your cut 6" out from the root. The actual stab half is 6"x3" and the rest is elevator. Let me know if I can help with anything else.
_____________________________
William McClooney
(in reply to SDR-Hammer)
       Post #: 77
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/3/2004 5:03:35 PM
gasrc
Status: offline
Your wing is perfectly flat-top. Does this have any different flight characteristics than the SPA3D wing as illustrated on spadtothebone?
Also, what do I as for when looking for the fuse material? Doing a web search brings up every shape and form known to man, besides the nearly square tube that you used.
(in reply to mnrcaerobat)
       Post #: 78
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/3/2004 7:32:24 PM
novabill
Status: offline
quote:
ORIGINAL: gasrc
No incidence problems. You do'nt have to reflex the ailerons up to get it to fly straight and it stays trimmed out within a broader speed envelope.
William McClooney
(in reply to gasrc)
       Post #: 79
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/3/2004 8:36:05 PM
gasrc
Status: offline
Thanks.
1 mo question
What do I ask for when looking for the fuse material? Doing a web search brings up every shape and form known to man other than the nearly square tube that you used.
       Post #: 80
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/3/2004 8:58:54 PM
novabill
Status: offline
Tractor supply is where I get mine, do you have one of them locally. Electric Fence Post Insulator is what we call it. It is spaced between the main posts of an electric fence
William McClooney
(in reply to gasrc)
       Post #: 81
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/3/2004 10:09:21 PM
gasrc
Status: offline
quote:
ORIGINAL: novabill
How about a pic of the raw material, please (as purcahsed)? That way I can just print it and show the salespeople rather than having to unproductively explain it.
All I can find is stuff like THIS
< Message edited by gasrc -- 5/3/2004 10:25:45 PM >
       Post #: 82
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/4/2004 12:36:46 AM
SDR-Hammer
Status: offline
Thanks for the info. It could have been the way I cut the tips, tried to get a little fancy and probably got some flutter.
That’s what I like about these planes, try something out if it doesn't work cut new pieces, less than five minutes back in business again.
       Post #: 83
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/4/2004 1:43:47 AM
davo74
Status: offline
Here is how i got rid of the music wire to hold the air foil, i took a piece of 4mm and cut it 12 flutes wide by about 2 inches long, bent it into a u shape and used 3m vhb tape to stick it in. I put on at the end and one in the middle of each wing, seems to work good, and no music wire.
Click to see fullsize image.
Click for fullsize
< Message edited by davo74 -- 5/3/2004 8:44:45 PM >
       Post #: 84
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/4/2004 3:02:40 PM
novabill
Status: offline
quote:
ORIGINAL: gasrc
quote:
ORIGINAL: novabill
I will try to stop by TSC and get you a part number and the real name of the stuff today. Here are some pics of the damage caused by a recent crash and the new peices used to fix it. It's a YAK now.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
William McClooney
(in reply to gasrc)
       Post #: 85
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/4/2004 8:55:45 PM
gasrc
Status: offline
Thanks. That will be great.
That must have been some crash to damage the front and the rear! What happened?
In one of your new crash pics, it appears the insulator is 1 x 1.5 solid. Or is that just the remains of your engine mount stuffed in the tip? I assumed it was square(ish) tube.
< Message edited by gasrc -- 5/4/2004 8:57:18 PM >
       Post #: 86
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/5/2004 2:16:23 AM
novabill
Status: offline
quote:
ORIGINAL: gasrc
Hee Hee, I can crash with the best of them. I was practicing breaking #9 and had to pull out. The Webra .50 is awesome on this plane and all it took was a split second when I missed the throttle stick to run it up, over my head and into the ground behind me. It hit really hard. Somehow the elevator bent all the way around and was pointing at about 150degrees. My kids (who were standing under the shelter) "safety first" were rolling in the dirt. It really was funny, cause it was a spad. The two old men at the field flying the Cub were really pi**ed at me, but I did'nt care because they were in the pits changing a broken prop and I was 50 yards away. Come to think of it, I do'nt think they ever got the thing up. The motor mount shattered and what you see in the pic is the remains. (It was american chef brand too). The EFI is 1"x 1.5". That's why I use 3/4" foam doubled up.
I will be giving the plane to my good friend Alex in june, as I am starting a new improved plane "The Coro Katana" with a foam fuse and symmetrical wing. I did'nt get to TSC today, hopefully I can go by in the next two days.
William McClooney
(in reply to gasrc)
       Post #: 87
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/7/2004 9:51:38 PM
gasrc
Status: offline
Hey bill. Did you ever get pics and info on that fuse material?
       Post #: 88
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/8/2004 3:37:27 AM
novabill
Status: offline
quote:
ORIGINAL: gasrc
sorry man. I will get on it asap
William McClooney
(in reply to gasrc)
       Post #: 89
RE: SPA3DEFI-PROFILE-Flight Report & Pics - 5/12/2004 6:15:30 AM
