LouW
Joined: 1/1/2003 From: Moreland, GA, USA Status: offline
Actually the Bernoulli equation is a mass balance (conservation of mass). It simply states that within the confines of a stream tube , the mass passing through each section must be equal. Obviously if the section gets smaller, the velocity of the mass must increase. This increase in velocity can only happen if there is an unbalanced force. To exist, this force demands a lower pressure at the smaller section in order to accelerate the mass. It is only valid for a fluid that is incompressible (which air is not) and inviscid (which air is not), and for flow confined within a stream tube. Within the limits of its’ derivation, it is an extremely useful concept. It is not a matter of whether Bernoulli or Newton is right. In fact they are simply two ways of looking at the same thing. If you are designing wing sections and need to explore the pressure field around an airfoil, Bernoulli is the only way to go, but if you are flying an aircraft that is already designed and built, Newton gives a better understanding of what is going on. In fact the air is not flowing at all. It is essentially still, and the airplane is moving through it. This doesn’t make any difference as far as the pressure distribution around the wing is concerned, but is highly significant to a pilot, who is trying to move along a certain path through the air. In either case, the overly simplified explanation of lift, usually seen in popular books involving a flat bottom airfoil, is not quite accurate. Bernoulli works just as well for a flat plate moving at some angle of attack as it does for a Clark Y. As I stated before, if angle of attack is related to the zero lift line (rather than the chord) it becomes obvious that it is really the secret of lift.
