bluesilver30
Joined: 11/28/2003 From: Rumson, NJ, USA Status: offline
"ps: DAMN IT, im just a teenager that love rc toy (helicopter) and just wanted a damn helicopter that can fly and kinda cheap in my budget. " there in lies the problem. there is no such thing as an rc heli that you can just pick up and fly. i have a hummingbird, and i say i put in 3 hours of work into it for every hour of flying. it was a lot more time when i first got it. first of all, you dont need to go seperates, you dont need to go mod it, you dont need to do anything. it will fly as is. there are many things that could be causing a problem. maybe you got a type 1 tx and have your rx wired for type 2? maybe your throttle trim is set too high so the esc is not arming. maybe you have a loose wire. maybe there some soder came undone on the motor. maybe you did get a bad part. it's really trial and error. if you can, take pictures of your setup and we will be able to help you more. but you really have to understand that these things are not toys. they are models, and especually true for micro's they are a very new thing. we are the pioneers for these small electronic heli's, and as for all pioneers of something new we have it the hardest. just stick with it, use the boards such as here, runryder.com, and rcgroups.com to help. although you got a RTF heli so you should be flying soon then me, consider this. i spent about a month setting up my helicopter before my first flight. i recieved a bad battery when i ordered it, and so i did so much to try and fix it. i trouble shooted every single system on my heli. it payed off though, because now i know exactly how these heli's work and what i can do to improve them. just be patient, you'll get it flying. there is no such thing as a broken heli . everything can be fixed.
< Message edited by bluesilver30 -- 2/17/2004 8:52:47 PM >
_____________________________
Man's flight through life is sustained by the power of his knowledge.
