mad scientist
Joined: 2/18/2004 From: humble , TX, USA Status: offline
Yeah, that sounds cool in theory, but with a multi engine car, RPM is more what you look for. Twin .46s don't rev out like smaller motors and are murder on driveline parts. That car is actually pretty light, so it doesn't need alot of torque. As far as 1 big tank on the Tmaxx, if there was only 1 tank each engine would need a valve on the fuel line and exhaust line. If only 1 or 2 motors are run, the pressure from the tank would still feed the motor not running and flood it. Also, the pressure to pressurize the tank would bleed off through the muffler that is not running and make no fuel pressure. I looked into all of that, and for tuning the motors, separate tanks just worked better.
