mad scientist
Joined: 2/18/2004 From: humble , TX, USA Status: offline
OK, first, all three engines power the same spur gear on the trans. The reciever is located on a plate between the fwd body posts. The fuel tanks are mounted on a shelf about 1" above the chassis with all of the wiring between 2 steering servos ( one on each side). This truck has broken about every part you can think of, even stuff it shouldn't break. It has a ton of power (8HP) and yes it does run. With steel CVDs and driveshafts, full metal trans and racing gears with rear spool it is at the point where I can actually drive it for more than a few minutes.
