8.4 or 9.6 li-po
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> 8.4 or 9.6 li-po
Page: [1]
Login
8.4 or 9.6 li-po - 2/19/2004 6:40:12 PM
zibobman
Status: offline
hi,
well if i have a brushless motor that works on 8.4 or 9.6 volts,can i find lithium polymers for it?
cauz all i can find 7.4 v or 11.1 volts
any ideas?
thanks,
       Post #: 1
RE: 8.4 or 9.6 li-po - 2/19/2004 8:04:47 PM
Matt Kirsch
Status: offline
Lithium cells are 3.7 Volts per cell. Sorry, no way to get exactly 8.4 or 9.6 Volts. Not that it matters.
In reality, a 7.4 Volt Lithium pack is equivalent to an 8.4 Volt NiMH pack. All packs suffer from "voltage depression" under load, where the voltage is lowered by the load put on the battery. Properly sized, a 7.4V LiPoly pack won't suffer nearly as much voltage depression as an 8.4 Volt NiMH pack. Under load, an 8.4V NiMH pack will read around 7 Volts. Under load, a 7.4V LiPoly pack will also read about 7 Volts.
You can also go to an 11.1V LiPoly, and run a smaller prop or a higher gear ratio to keep the Amps down. In most cases, it's the excessive Amps that kill the motor.
(in reply to zibobman)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
