RE: YT International ADRENALINE
Tower Hobbies
Logged in as Guest
  Printable Version
PARK ZONE F-4U CORSAIR
Seller:  harleydoberman
Details:   $279.99   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> RE: YT International ADRENALINE
Page: <<   < prev  17 18 19 20 21 22 23 24 [25] 26   next >   >>
Login
RE: YT International ADRENALINE - 11/6/2006 6:27:09 PM
Gregor Giliams
Status: offline
[image][/image]
Some pics of my adrenaline.... check the enginecowl and the wings...
http://www.mijnalbum.nl/Foto=GPOKD7R8
http://www.mijnalbum.nl/Foto=NUIZZAKK
http://www.mijnalbum.nl/Foto=HKHOSCTF
http://www.mijnalbum.nl/Foto=YHJSDEWJ
Hope i will be flying it soon
(in reply to sh)
       Post #: 601
RE: YT International ADRENALINE - 11/6/2006 9:00:00 PM
twoturnspin
Status: offline
Interesting, looks like you've got the new style model with the old color scheme, didn't know it was was manufactured this way. I'll be interested in the weight when completed because I have a blue/yellow one I haven't got in the air yet.
_____________________________
Check out www.qpfa.org.au for info about aerobatics in Queensland
Wife:How many more planes do you need? Me:One more.
(in reply to Gregor Giliams)
       Post #: 602
RE: YT International ADRENALINE - 11/6/2006 9:37:26 PM
Jonathan.Lam
Status: offline
i've got the blue and yellow one and it comes out at 4.6kg
wat about yours?
Jonathan.Lam
(in reply to twoturnspin)
       Post #: 603
RE: YT International ADRENALINE - 11/6/2006 10:31:22 PM
Julius-Alexander
Status: offline
4,6 kg... WOW ! Is it well for the 120 size?
Anyone got the weight of the 2M?
JAM.
< Message edited by Julius-Alexander -- 11/6/2006 10:34:33 PM >
(in reply to Jonathan.Lam)
       Post #: 604
RE: YT International ADRENALINE - 11/6/2006 11:13:04 PM
twoturnspin
Status: offline
That's depressing Lil Chinky b0i, very heavy. What motor & gear have you got in it? I was hoping to get mine down to 4kg with a TT120RP & pipe.
(in reply to Julius-Alexander)
       Post #: 605
RE: YT International ADRENALINE - 11/7/2006 9:15:34 AM
kinverflyer
Status: offline
The 2M depending on motor 11lb to 14lb
       Post #: 606
RE: YT International ADRENALINE - 11/7/2006 1:43:18 PM
Gregor Giliams
Status: offline
When wil it be flying twoturnspin? as mine will be powerded by the same engine with pipe i'm curious about the performance .
       Post #: 607
RE: YT International ADRENALINE - 11/7/2006 5:17:16 PM
Jonathan.Lam
Status: offline
quote:
ORIGINAL: twoturnspin
i've only got a saito 125 (which isnt powerful enough ) - standard muffler and the hangar 9 hardware kit thats all
how much does yours way?
Jonathan.Lam
       Post #: 608
RE: YT International ADRENALINE - 11/7/2006 11:07:41 PM
twoturnspin
Status: offline
Hi Gregor,
I hope to have in in the air in December after our Pattern Flying Season finishes. I've got most of the bits for it now, just waiting on a Hyde mount and then I'll be good to go! I had a Dubro vibration reducing mount on it but wasn't very happy as the airframe still shook a fair bit and I found that the front end of the fuze pulled away from the base after about 50 flights, hopefully the Hyde mount will reduce this effect on the new Adrenaline.
My full setup will be:
TT120RP & pipe(Dave Brown Hush Clamp on pipe to reduce vibration).
Hitec digital servos (HS81MG throttle, HS6635 Elev & Aileron, HS6865 Rudder)
JR RS10DS Rx (10 ch dual conv, synth), 2000mah 6.0V NiMH
CF wing tube & gear
I'm still hoping the weight will be a lot less than 4.6kg. My 2M Pattern Plane comes out at 4.8kg and it's powered by a 140Rx.
       Post #: 609
RE: YT International ADRENALINE - 11/9/2006 10:11:56 AM
Gregor Giliams
Status: offline
I now have a F3A model with a saito 150.... it's also about 4.8 kg so my performance would increase a bit i reccon with the adrenaline and a 120 TT....
Btw, You using the original hingeses... i think i would preffer real 2 piece items or are the original up for the job?
thnx
< Message edited by Gregor Giliams -- 11/9/2006 11:13:59 AM >
       Post #: 610
RE: YT International ADRENALINE - 11/9/2006 8:53:56 PM
twoturnspin
Status: offline
I didn't like the originals so I replaced with Sig Easy Hinges. They have been great, no breakages and they are well priced..
       Post #: 611
RE: YT International ADRENALINE - 11/10/2006 2:35:05 PM
Jonathan.Lam
Status: offline
i used great plane ultra storng hinges - no problem at all
Jonathan.Lam
       Post #: 612
RE: YT International ADRENALINE - 11/20/2006 6:10:16 PM
Gregor Giliams
Status: offline
Hej Twoturnspin,
How did You get the engine and header in place as whit the rear ported engine the header doesn't fit this plane??
An xtra sillicone hose to get lower or just reweld the header?
Thanx.
< Message edited by Gregor Giliams -- 11/20/2006 8:26:40 PM >
       Post #: 613
RE: YT International ADRENALINE - 11/21/2006 4:03:03 AM
twoturnspin
Status: offline
Hi Gregor,
I haven't got the engine and pipe into my new Adrenaline as yet. The pipe and header fitted in fine in my red/white Adrenaline so I was hoping that it would be able to be mounted in the new airframe without modifcation. My Hyde mount has arrived but I won't be able to get back to the installation for a couple of weeks. If the header doesn't fit I will probably rebend the header to fit rather than re-weld or use extra silicon hose.
Hyde mount looks sensational, I will be really interested to see ow it runs in the plane over the Christmas period.
All the best, Twoturnspin
