twoturnspin
Joined: 3/27/2003 From: Brisbane, AUSTRALIA Status: offline
Thanks for the idea Kinverflyer, I'll see if I can rustle up a 17x6. By the way, did you close off some of the inlet cooling or open heaps of room in the belly pan? I'm a bit paranoid about cooling having cooked a TT120 previously, it is also quite warm & humid over here at present. The weekend's flying was in 30 deg c with high humidity. Merengue, bought the CF tube from Precision Aerobatics over here, they were very fast considering that they had to have it manufactured, only cost AUD62. I think it was 1" (ie. 25.4mm) and it fitted perfectly as delivered. Good luck getting into the air Gregor, it must be pretty cold over there this time of year and not much sunlight. I was in your beautiful country in June and enjoyed gloriously long days so you really have the advantage at that time of year!! Twoturnspin
_____________________________
Check out www.qpfa.org.au for info about aerobatics in Queensland Wife:How many more planes do you need? Me:One more.
