lechuza -> RE: Long EZ owners( Mine Flies finally!!!) (8/25/2008 8:08 AM)
Hello, I just finished my Richmodel Long EZ 160, with a OS MAX 1.60FX, and I set the C.G. according to the instructions manual of 451mm from the trailing edge of the main wing toward the nose of the airplane.With that setting, I had to use the 6 weight bars that comes with the model to get that C.G. position.Maiden flight and almost crash due to excesive nose heavy, was hard to takeoff and fly, I removed 3 weight bars, went airborne and still nose heavy and difficult to fly and then all weight bars removed, went airborne again and still unable to fly well, and can not hold straight and level flight.Model weights about 16 pounds. Those who owns this model, what can I do in order to get the correct C.G., which is the correct one? Thanks, Isaias G.
