2 Stroke engine help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 Stroke engine help
Page: [1]
Login
2 Stroke engine help - 2/22/2004 5:11:56 PM
Quick 1
Status: offline
Hello, I need some help on the low end needle adjustment setting and where is a good place to start? The motor is an os max .25! Any help would be greatfull thanks!!!
       Post #: 1
RE: 2 Stroke engine help - 2/22/2004 10:24:08 PM
sandal
Status: offline
You should get it started if you adjust the air bleed screw to cover half the hole.
If it sounds rough and quits idling after a while, turn the screw out 1/4 of a turn and try again until it idles well. If it dies when you hit the throttle, turn the screw in 1/4 of a turn.
I don't have experience with old engines like the Max .25, but this method works well with LAs and FPs, and their carburettors are similar. Hope it helps.
(in reply to Quick 1)
       Post #: 2
RE: 2 Stroke engine help - 2/24/2004 2:20:05 PM
Quick 1
Status: offline
Thank you very much!
(in reply to sandal)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
7.156RCU1
