RE: northstar help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> RE: northstar help
Page: <<   < prev  11 12 13 14 15 16 17 18 19 [20]
Login
RE: northstar help - 5/5/2008 11:17:33 AM
Mustang Fever
Status: offline
Congrats, Simon.
They both look nice. So.. the shim was 1/8" thick at the top and tapered to the bottom?
I'll have to try that on my drawings and see if I can make a propeller fit in the remaining space.
I've started a build thread on another one at:
http://www.rcuniverse.com/forum/m_7287178/anchors_7287178/mpage_1/key_laddie%252Carrow/anchor/tm.htm#7287178
< Message edited by Mustang Fever -- 5/5/2008 11:19:23 AM >
_____________________________
Bob Hunt
(in reply to simhatus)
       Post #: 476
RE: northstar help - 5/5/2008 1:25:03 PM
Mustang Fever
Status: offline
Simon:
I think I'll make a 1/8 shim like you did, only put it between the engine mount and the firewall, then move the engine mount up about 1/8" inch from plan. That should give the same thrust line and downthrust without the necessity of changing the angle on the upper pylon rib, etc. I should be able to shape the cowl so that everything comes out looking right.
I drew a 1/8 shim on my plans, and extended everything out. It measures at 3 degrees downthrust.
Do you have any information you could share on the C of G? There's a lot of discussion about that on this side of the pond. I know for certain that if one balances the A/C on the rearmost mark with an empty tank, that it will be uncontrollable in pitch. I'm considering balancing mine at about 11-12% of MAC with a FULL tank for the first flight.
Regards
Bob Hunt
(in reply to Mustang Fever)
       Post #: 477
RE: northstar help - 5/5/2008 9:16:10 PM
simhatus
Status: offline
Hi Bob
thanks.
Yes 1/8" at the top tapered.
I'll check were the cg now is.
Simon
< Message edited by simhatus -- 5/6/2008 3:32:35 AM >
       Post #: 478
RE: northstar help - 5/18/2008 6:26:19 PM
simhatus
Status: offline
Hi
Sorry for the delay will work out the cg shortly havn't forgotten.
Simon
       Post #: 479
RE: northstar help - 5/18/2008 9:40:36 PM
Mustang Fever
Status: offline
Thanks, Simon.
Bob Hunt
       Post #: 480
RE: northstar help - 5/23/2008 11:20:48 AM
simhatus
Status: offline
Hi
The cg for my arrow fully rigged with no fuel is 408mm from the trailing edge of the wing.
I picked the trailing edge of the wing to measure from as its likely to be somthing that dosn't vary on Individual models.
A further point to note is that my arrow does not have the wing strakes i decided to leave them off after flying somone elses arrow that flew well without strakes.
I think i'll go and find the plan and see how this compares to the suggested cg.
Simon
       Post #: 481
RE: northstar help - 5/23/2008 1:56:24 PM
Mustang Fever
Status: offline
Simon:
Is that from the elevon TE, or just the wing itself? (Measuring it out, I'm guessing you went from the TE without including the elevon)
Thanks much
< Message edited by Mustang Fever -- 5/23/2008 2:06:11 PM >
Bob Hunt
       Post #: 482
RE: northstar help - 5/23/2008 4:50:54 PM
simhatus
Status: offline
Hi
yes from the wing itself.
Simon
       Post #: 483
RE: northstar help - 5/24/2008 1:36:12 AM
Mustang Fever
Status: offline
Thanks, Simon
I really appreciate it.
Bob Hunt
       Post #: 484
RE: northstar help - 6/24/2008 1:54:14 PM
Mustang Fever
Status: offline
Simon:
I maidened the Arrow today, and couldn't be more pleased. It will take me all day to calm down. Thanks so very much for your help with CG. The complete story is on the other thread:
http://www.rcuniverse.com/forum/m_7287178/anchors_7654687/mpage_5/key_/anchor/tm.htm#7654687
Regards,
Bob Hunt
       Post #: 485
RE: northstar help - 7/6/2008 8:44:24 PM
erazz
Status: offline
Hi guys,
Is the Morris kit still available? Their website is down and I can't seem to reach them... Any idea?
BEWARE - WE ARE IN THE AIR
       Post #: 486
Jump to:
