Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Northstar follow up : ARROW by Laddie Mikulasko !
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 02-22-2004, 04:04 PM
Strykaas
Default Northstar follow up : ARROW by Laddie Mikulasko !
Hello,
I've just discovered the Arrow, a new sea plane design by Laddie Mikulasko... It is somewhat similar to the Northstar, except it is a true delta wing design.
Has anyove ever heard about it ? Any feedback ? Performance ? Available plans ? Or even kitted ?
thx
ID:	103829   Click image for larger version
Old 02-22-2004, 04:53 PM
jrf
My Feedback: (551)
Default RE: Northstar follow up : ARROW by Laddie Mikulasko !
It is scheduled to be a construction article in an upcoming issue of RCM.
Jim
Old 02-22-2004, 10:11 PM
Lake Flyer
My Feedback: (13)
Just what we needed, another lawn dart[]
Old 02-23-2004, 03:15 PM
Strykaas
ORIGINAL: Lake Flyer
what do you mean ?
Old 02-23-2004, 06:12 PM
alasdair
alasdair's Avatar
It looks OK, but I prefer the Northstar's looks. And the performance!!!
Ab fab
I've had two and they were wonderful.
I want another
-- with a Jett 50
No, a 90 ducted fan
No, a turbine.
Anybody seen a turbine powered Northstar?
Alasdair
Old 02-23-2004, 06:34 PM
Strykaas
I agree, I did not mention it, but I prefer the Northstar look. However, this design may fix the tail heavy configuration, as there is no stabilator any more.
No more tip floats as well... Too bad !
Old 02-24-2004, 01:42 PM
MinnFlyer
MinnFlyer's Avatar
Looks interesting, but how about this mod?
Old 02-24-2004, 04:22 PM
Strykaas
Excellent [sm=thumbup.gif] Minnflyer ! It improves the look, definitely ! Handling too, probably ...
Old 04-05-2004, 01:29 AM
CrazyHerb
CrazyHerb's Avatar
Probably just jacked the CG up all over again too...hehehe..
I agree canards look good though...
I do like the simplicity of the Arrow design though.... I like em both...
LADDIE...need a kit review??? Send one my way!!! Hehehe...
I'll end up just making a foamie version of it though.....
CrazyHerb
Old 05-27-2004, 08:57 PM
rcairplanenut
The June issue of RCM has the construction artticle
http://www.rcmmagazine.com/e/env/000...ml?command=env
thats the link for the plans
hope it helps
sgg
Old 05-27-2004, 08:59 PM
rcairplanenut
DOE
the plan number is 1335
type that into the rcm plan search
im waiting for ups to bring me my arrow plans
sgg
Old 05-28-2004, 03:01 PM
Strykaas
Thanks a lot for pointing out the link.
I'll order mine soon ! Keep us posted about yours ;-)
Old 05-28-2004, 03:40 PM
mscic-RCU
mscic-RCU's Avatar
without the tip floats they are tough to get up on plane.
Old 06-01-2004, 09:08 PM
rcairplanenut
I finally got to look at the construction article via my RCM log in and I see good and bad.
I am defiantly NOT going to have removable wings; I have found them to be unnecessary and heavy on a delta aircraft. L.M. does not have the prop clearance in the construction article. Right now I’m thinking about a GMS .61.Im going to change around the shape of the nose of the fuse to look more like a shark rather then a stake. The good news is it looks a lot easier to balance then the North Star. I can also believe the weight estimate being around 5 lb * or – on this airplane.
Hope to get started ASAP on this one.
Still waiting on UPS for the plans.
SGG
Old 06-03-2004, 11:42 PM
rcairplanenut
Got the plans today
things look good
SGG
Old 06-04-2004, 09:36 PM
rcairplanenut
here are the nose mods, shown in red on the plans
SGG
ID:	139577   Click image for larger version
Old 06-05-2004, 06:31 AM
Strykaas
SGG
what are these mods ?
Old 06-06-2004, 01:30 AM
rcairplanenut
I changed the shape of the nose around; it is shown in red in the pictures.
Most important is giving the “sea plane” a boat nose that will keep it from turning into a submarine!!!
The second is a wider nose viewed from the top giving it more room for a battery and ballast weight.
Old 06-06-2004, 05:06 AM
Strykaas
ok thx
Will you implement the canards ?
Old 06-06-2004, 10:04 PM
rcairplanenut
Todays progress
Doing the usual sheeted truss thing, the alignment is flawless rather then the balsa sheet construction.
No canards for me, just a different nose, non removable wings, and sheeted truss fuse
ID:	140293   Click image for larger version
ID:	140294   Click image for larger version
Old 06-07-2004, 01:30 PM
Strykaas
Well keep up the pix !!!! great thank u
Old 06-10-2004, 12:00 PM
rcairplanenut
The progress so far
Note the Carbon Fiber in the sides of the engine pod, on the red back ground
ID:	141758   Click image for larger version
Old 06-11-2004, 01:22 PM
Villy
So how are you coming with it ???
I am thinking about getting back after a hiatus of almost 20 years. I would be interested to know what skill level is required to successfully fly this bird.....
(actually I got out just after Laddie published the plans for the Northstar, and I guess that my question would apply to this one as well. Some comments from anyone that has built the kit would be appreciated!)
Villy
Old 06-11-2004, 02:41 PM
rcairplanenut
Hi Villi
I have built and flown the North Star and its flight performance can not be beat, its also not that difficult to fly if you are used to an aerobatic type aircraft.
How ever I have found that the North Star has 3 construction/engineering flaws.
1 it takes a gross amount of lead weight in the nose to make it balance.
You can solve this by making the nose longer so it will take less weight, teeter_totter stuff exc…………..
2 The throttle and elevator controls are very sloppy on the NS, even though it would mean 3 more oz in the tail (2 servos in the pod) it is worth it to put direct connections for the elevator and throttle. Bell cranks might be another possibility
3 Each aileron needs its own servo, they need to work as flaperons. It is drastically more effective to trim pitch with flaperons rather then the elevator on the North Star.
You can do all these changes to the North Star, but Laddie solved all 3 problems with the Arrow.
So far I am pleased with the way my Arrow is coming out with the construction. The main thing I have noted is that the Arrow is the simplest float plane you can build.
SGG
Old 06-11-2004, 10:40 PM
Villy
Thanks Spence
No - not used to an acrobatic aircraft. - My last one was a Stick!!
Think I should probably build a Telemaster 40
That should be staid enough for me.....
Villy
