jchumley -> RE: Caproni Ca.42 (8/6/2004 4:23 PM)
Well. Third flight accomplished. Went pretty well. 10 - 12 mph gusty crosswind. After repairing the cabanes and adding sum wire support to the nose, it was a bit out of trim but not too bad. I had some problems turning it when flying down wind. It wants to pop up and then it almost stall turns. I think I need to use a lot more rudder when turning. The wind caught it on landing and turned it almost 90 degrees. After the last time, I didn't even try to correct it but held it steady until it hit the tall grass. Best part is I got video. My connectin here in maine is very bad so I can't view the video on line. Would someone please let me know if they load and play properly? Jeff http://www.rcuniverse.com/forum/m_2042101/anchors_2042101/mpage_1/key_caproni/anchor/tm.htm
