jchumley
Joined: 12/4/2002 From: Dunkirk, MD, USA Status: offline
Very nice. Looks like the real thing. You are building much more scale than I am but I too am planning a larger detailed scale version. This one is for an actual combat type event where it will tow a ribbon and be protected by a flight of fighters against a flight of enemy fighters. The risk of damage is high. That, and the fact that I have only had about 3 months to work on it in my spare time meant that I could only go semi sport sorta kinda scale. I hope to fly it this Sunday. I decided to go with three engines after all. It looks like it will still come in around 6.5 lbs and be a real floater. Can't wait to fire up the three saito .30s. should sound really cool. It should probably fly easily at considerably less than full throttle. (if it flies at all!) You have an advantage with the Ca.3, there are several good reference works on it. I have Gregory Alegi's Windsock Datafile on it and it is good. THe Ca.42 is not nearly as well documented. I have one book in Italian that shows some detailed construction drawings of the center nacelle, the landing gear and tail skids and some of the strut mounting hardware. anything that I can't document I will use the Ca.3 documentation. I am not sure whether I will go 1/8 scale (12' wingspan) or 1/12 scale (8'). I can tell you that I will be tired of making ribs by the time I am done. Even for this one which has much wider rib spacing, I had to make over 150 ribs! I have heard that the Caproni Museum in Trento, Italy has a model of a commercial version of the Ca.42 but have been unable to contact them about it. WHen I get to designing a scale version, some time spent with that model would be very helpful. Your rudders look great with all the wires and braces. How did you attach the bracing rods to the center rudder without inhibiting rotation and what mechanism did you use to fit the rudders to the elevator? Jeff
