RE: How does a brushless motor work?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Tenergy 6V 2000mAh NiMH RX Receiver Battery Pack w/ U Connector ***FREE SHIPPING
Seller:  swgiantscalemodels
Details:   $12.99   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> RE: How does a brushless motor work?
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: How does a brushless motor work? - 7/19/2006 2:04 AM
cap85king
Score: 100
Last Login: 8/14/2008
Status: offline
If you go onto www.wikipedia.com and search "brushless motor", they have all kinds of motor info, a lot I didn't understand, (Wikipedia has long articles). Here's the "basic" info from the site:
A brushless DC motor (BLDC) is a DC electric motor that uses an electronically-controlled commutation system, instead of a mechanical commutation system. (The rest of this article assumes the reader is familiar with the principles of electrical motors.)
Because of induction of the windings, power requirements, and temperature management some glue circuitry is necessary between digital controller and motor.
The poles on the stator of a two-phase BLDC motor. This is part of a computer cooling fan; the rotor has been removed.
B=Magnetic Flux. It is uploaded as SVG, the vektor-graphics-format, that anybody can edit.Three subtypes exist:
The three-phase AC synchronous motor type has three electrical connections
The stepper motor type may have more poles on the stator.
The reluctance motor has all its poles on the stator, and a magnetic core on the rotor.
In a conventional (brushed) DC-motor, the brushes make mechanical contact with a set of electrical contacts on the rotor (called the commutator), forming an electrical circuit between the DC electrical source and the armature coil-windings. As the armature rotates on axis, the stationary brushes come into contact with different sections of the rotating commutator. The commutator and brush-system form a set of electrical switches, each firing in sequence, such that electrical-power always flows through the armature-coil closest to the stationary stator (permament magnet.)
In a BLDC motor, the brush-system/commutator assembly is replaced by an intelligent electronic controller. The controller performs the same power-distribution found in a brushed DC-motor, only without using a commutator/brush system. The controller contains a bank of MOSFET devices to drive high-current DC power, and a microcontroller to precisely orchestrate the rapid-changing current-timings. Because the controller must follow the rotor, the controller needs some means of determining the rotor's orientation/position (relative to the stator coils.) Some designs use Hall effect sensors to directly measure the rotor's position. Others measure the back EMF in the undriven coils to infer the rotor position, eliminating the need for separate Hall effect sensors, and therefore are often called "sensorless" controllers. (The BLDC motor has a trapezoidal backemf, while a brushless AC motor has a sinousoidal backemf.)
BLDC motors can be constructed in two different physical configurations: In the 'conventional' configuration, the permanent magnets are mounted on the spinning armature (rotor.) The stator coils surround the rotor. In the 'outrunner' configuration, the radial-relationship between the coils and magnets are reversed; the stator coils form the center (core) of the motor, while the permanent magnets spin on an overhanging rotor which surrounds the core. In all BLDC motors, the stator-coils are stationary.
[edit]
Comparison with brushed-DC motors
BLDC motors offer several advantages over brushed DC-motors, including higher reliability, longer lifetime (no brush erosion), elimination of ionizing sparks from the commutator, and overall reduction of electromagnetic interference (EMI.) BLDC's main disadvantage is higher cost, which arises from two issues: First, BLDC motors require high-power MOSFET devices in the fabrication of the electronic speed controller. Brushed DC-motors can be regulated by a comparatively trivial variable-resistor (potentiometer or rheostat), which is inefficient but also satisfactory for cost-sensitive applications. BLDC motors need a more expensive integrated circuit, called an electronic speed controller, to offer the same type of variable-control. Second, when comparing manufacturing techniques between BLDC and brushed motors, many BLDC designs require manual-labor, to hand-wind the stator coils. On the other hand, brushed motors use armature coils which can be inexpensively machine-wound.
BLDC motors are considered more efficient than brushed DC-motors. This means for the same input power, a BLDC motor will convert more electrical power into mechanical power than a brushed motor. The enhanced efficiency is greatest in the no-load and low-load region of the motor's performance curve. Under high mechanical loads, BLDC motors and high-quality brushed motors are comparable in efficiency.
_____________________________
If you cry, and I don't see it, I'm just gonna have to make you cry again.
Hide Signatures
(in reply to scott88-RCU)
       Post #: 76
RE: How does a brushless motor work? - 12/26/2006 6:52 PM
cujo_77
Score: 100
Last Login: 3/8/2008
Status: offline
I found this and I think it easily explains how a brushless engine works.
http://electronics.howstuffworks.com/brushless-motor.htm
Hide Signatures
(in reply to cap85king)
       Post #: 77
RE: How does a brushless motor work? - 2/6/2007 9:30 PM
JCORLEY
Score: 100
Last Login: 2/9/2007
Status: offline
quote:
ORIGINAL: Matt Kirsch
A popular myth that I fell victim to myself. Turns out that even though the ESC does switch the polarity back and forth on the various phases of the motor to make it turn, it's still putting out DC voltage. It's similar to AC, but the wave is a "square" type. Unlike AC, where the voltage gradually changes from maximum + to minimum -, producing a "sine" wave, this switched DC changes from full + to full - instantly.
The picture below kind of shows what I mean. This is what you'd see on the screen of an oscilliscope if you compared true AC to what the brushless ESC is doing, sort of, kinda, maybe
would this be the same as pwm and what changes with rpm height or width
Hide Signatures
(in reply to Matt Kirsch)
       Post #: 78
RE: How does a brushless motor work? - 2/16/2007 11:18 PM
pilotpete2
Score: 120
Last Login: 5/22/2013
Status: offline
With PWM the longer the "on" time the higher the effective voltage, resulting in increased RPMs, this part of a brushless ESC is essentially the same as in a brushed controller, though brushed controllers tend to use a lower frequency for PWM.
The PWM is performed before the commutation/switching part of a brushless ESC, the PWM is the means used to control the speed by varying the effective voltage provided to the motor. With PWM the width of the pulse increases as the throttle is increased until the the DC voltage is "on" all the time at full throttle, this is the opposite of an AC Thyristor type control/dimmer that cuts off the voltage at variable levels to reduce the average voltage.
Brushless motors are commutation mode motors just as any brushed motor, only the mechanical commutation has been replaced by electronic commutation provided by the controller.
True AC motors do not have a Kv rating, as they are controlled by the frequency of the AC current, not the voltage applied. No AC motor on line or mains current can exceed 3600 RPM (60Hz) and induction type motors "slip" about 50 RPM below their synchronous speed at no load. Thats why brushed series wound motors are used for so many applications on AC, it's the only way to get 30K RPM out of your Dremel tool or any other appliance that requiers higher RPMs than AC motors can provide. Series wound brushed motors while used mainly on AC today, are classed as "universal" motors as they will run on AC or DC, brushed permanent magnet motors on the other hand run only on DC.
Regards,
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
(in reply to JCORLEY)
       Post #: 79
RE: How does a brushless motor work? - 3/31/2007 1:55 AM
Bcolici
Score: 100
Last Login: 3/29/2013
Status: offline
rotflmao
quote:
ORIGINAL: bil2
Scott, these guys are ALL wrong. Actually there's a bunch of tiny midgets that run back and forth inside the motor when you flip the switch on/off. The confusion arises because they run in a RECTANGULAR square trapizoidal sinusoidal rectal shaped direction, thus leading to MAGIC! (The easiest explanation is always the correct explanation. Magic works.) No thanks are necessary. Bil2
Later.
Hide Signatures
(in reply to bil2)
       Post #: 80
RE: How does a brushless motor work? - 6/16/2007 9:32 PM
Dave ESPI
Score: 100
Last Login: 10/25/2012
Status: offline
Great thread thanks answered all my questions
BOYCOTT BANANA HOBBY. Ripoff artist Pete is a scammer with no backbone. Don''t believe lies of "lifetime customer support".
Hide Signatures
(in reply to Bcolici)
       Post #: 81
RE: How does a brushless motor work? - 7/24/2007 8:23 PM
CGRetired
Score: 221
Last Login: 5/21/2013
Status: offline
To correct something that was posted early on in this thread, Voltage does not flow. Current does.
Skylark 70 - OS .75 AX; Excelleron 90 - OS 1.20 AX; Venus II - OS 1.20 AX; And, I still fly my trainer, Hanger 9 Alpha - OS .46 FX! Some electrics. Airtronics RD8000 - Spektrum DX7 - DX6i. AMA 705964.
Semper Paratus!
Hide Signatures
(in reply to Ron v. Sommeren)
       Post #: 82
RE: How does a brushless motor work? - 7/29/2007 10:22 PM
calvino
Score: 106
Last Login: 1/28/2012
Status: offline
Wow, I never really knew what operated it because of the 3 wires running out the back. Good question to ask.
Axial AX10, "Irene" with custom chassis, Thunder Tiger ST-1 [not working]
Hide Signatures
(in reply to CGRetired)
       Post #: 83
RE: How does a brushless motor work? - 8/17/2007 8:34 AM
mambamax
Score: 100
Last Login: 8/20/2007
Status: offline
im going to invest in the ''momba max'' brushless sistem anyone that can tell me if the pastic gearing will work? or do i have to upgrade to alloy?
MAX
Hide Signatures
       Post #: 84
RE: How does a brushless motor work? - 11/6/2007 11:03 PM
shinob1
Score: 100
Last Login: 1/1/2009
Status: offline
In regards to running two brushless motors on one rc ESC, it is not possible in either series or parallel. However, while it might be more expensive, two brushless motors on two ESC does work. If you have a programmable controller, you can set it up however you want, linking two channels to run on one stick, and trimming just the channels to get a "close match", i.e. both pulling/pushing at near the same rpm, or you can run each on its own stick, which i find personally to be quite fun, it opens up a new world of possibilities. Just remember if so inclined, you can only use one ESC as the BEC, otherwise you will ruin electronics, so make sure your set up properly that way. You will also be heavier because you will be flying with two battery packs as well, i guess it might be possible to split on pack, but that jsut seems like a bad idea to me. As for limits yes there are some. RPMs (to many and things break/shatter... like you magnets... sob), HEAT (to much and you will demagnetize your magnets... again... sob) are the most common two. As for torque, its not like on brushed motors, which is why you find most brushless motors to have a Kv rating and not a turn rating. You torque depends on how much power, i.e. Amps, you can supply to your motor. However, the higher the Kv, the hotter it will run. If you are in the car area you might find it helpful to invest in a temperature gauge (Venom Temp here personally).
MAX
And for the guy who asked about a mamba and his plastic gears, you can use plastic, but when they wear out and they will, replace them with something quality, otherwise you will keep eating up transmission repair costs.
and for sigman, yes if i understand you correctly that is how its done, but there are screws you have to loosen too. You should be able to go to horizonhobby.com and find out for your motor specifically. I think I've taken up enough space now....
Hide Signatures
(in reply to mambamax)
       Post #: 85
RE: How does a brushless motor work? - 11/6/2007 11:22 PM
pilotpete2
Score: 120
Status: offline
Hi shinob 1,
Good post, but one small quibble, turns and Kv are directly related, higher turns = lower Kv. Axi and many other motors give the number of turns in there numbering eg. Axi 22-12-34, 34 turns 720Kv.
To my knowledge BLDC motors are the only non- brushed motor to have a Kv rating. True AC motor do not have Kv ratings, their no load RPM is determined by number of poles per phase, frequency and the degree of slip in the case of asynchronous induction motors. The Kv rating is normally only associated with motors that run under the principle of commutation, traditionally only applied to brushed motors, but now with the development of BLDC motors sometime in the early 70's, also to motors without brushes.
Pete
Hide Signatures
(in reply to shinob1)
       Post #: 86
RE: How does a brushless motor work? - 11/8/2007 5:42 AM
shinob1
Score: 100
Status: offline
Thanks Pete for the clarification on that. I didn't mean to separate them like that. In my experience, and I run RC cars and planes, brushless motors are listed with Kv rating, especially on the aircraft side. Sometimes they only list a turn rating, or they'll provide both. I just wanted to emphasize that point that when talking brushed motors, on given motor size, say 550, it will lose torque as the turn rating decreases in value and gain an increase in rpm. (because a turn rating does involve torque, and when viewed properly the turn rating on brushless motors is really saying it is equivalent/surpasses a NN-turn brushed motor for the kv range... that make sense?) The wind (single, double, triple, and quad), as I understand from a hobby RC perspective, helps to determine where on the rpm range the motor will have the highest torque. Yes there is more to it, but generally when determining how many winds of a given turn would be chosen for a specific car/truck/boat/plane, it is where in the rpm range the torque is needed that will decide. But when dealing with brushless motors, again from a hobby perspective, the motor has close to the same torque through the entire rpm range. The way they wind the wires determines the Kv. The torque comes from the ability to supply the amps needed to spin the rotor load, more easily done in the brushless arena. Clearly I am not a physicist, but I do try to be knowledgeable where my investments are concerned. Please correct me on anything I may have portrayed obscurely or inaccurately.
Hide Signatures
(in reply to pilotpete2)
       Post #: 87
RE: How does a brushless motor work? - 11/20/2007 1:45 AM
bdvd100
Score: 100
Last Login: 11/22/2007
Status: offline
Has anyone here built a b/l from a kit - were you happy with the results - any issues....
Has anyone tried a kit from these guys?? thanks BD
http://www.innov8tivedesigns.com/
Hide Signatures
       Post #: 88
RE: How does a brushless motor work? - 11/20/2007 12:28 PM
UH60Mech
Score: 100
Last Login: 3/31/2008
Status: offline
I've been following this thread and all the techno babel is good to know info... (depending on your level of schooling in that sort of stuff)
But, (Please, LESS Techno-Babel) what are the difference between and InRunner or an OutRunner????
I see tht the can and venting are different and some of the InRunners I have seen have what looks to be ridges along the outside (Heatsink???)
Hide Signatures
(in reply to bdvd100)
       Post #: 89
RE: How does a brushless motor work? - 11/20/2007 10:48 PM
bil2
Score: 100
Last Login: 4/12/2009
Status: offline
The difference between the INrunner and the OUTrunner is easy.
Without techno-babble, the OUTrunner does this: the outer case (aka can) spins. The prop/ adaptor is bolted on the case.
On the INrunner, the shaft going through the middle spins. The outer case stands still.
The difference this makes is that the OUTrunner is swinging those magnets (inside the case) around. The weight of them spinning creates a lot more torque. Since you have a lot of torque, you don't need a gearbox to spin the prop - it can be bolted directly to the spinning case.
On the INrunner, you almost always have to use a gearbox to gear down the motor, thus creating the torque needed to spin the prop. Gearbox=unnecessary complications, noise, breakage.
Hope this helps,
Bil
Hide Signatures
(in reply to UH60Mech)
       Post #: 90
RE: How does a brushless motor work? - 1/16/2008 1:37 AM
shinob1
Score: 100
Status: offline
Having weight spin does not create more torque...? (Physics)
Hide Signatures
(in reply to bil2)
       Post #: 91
RE: How does a brushless motor work? - 1/16/2008 5:35 PM
bil2
Score: 100
Status: offline
I wonder why the original radial engines - you know, the ones where the engine spun, and the crankshaft remained in place? - why they went away? Was it torque? (yes - physics).
Ever ponder why your front wheel drive vehicle has "torque" steer? More horsepower = more "torque" steer? I suspect it has to do with "torque."
Maybe it should be called "inertia" but its not, its called "torque."
Hide Signatures
       Post #: 92
RE: How does a brushless motor work? - 1/16/2008 10:37 PM
pilotpete2
Score: 120
Status: offline
The WWI rotary engines disappeared for good reasons. As they had greater rotating mass than a radial engine, they created more gyroscopic progression. The rotary engine was not able to be throttled, they ran at full power and they "blipped" the ignition on/off to control power for taxing and landing (wow, sounds sorta like PWM controlling our electric motors )
I've been to Old Rheinbeck, so I've had the pleasure of hearing them actually run ,Ah, the sweet smell of Castor oil in the morning
Pete
Hide Signatures
(in reply to bil2)
       Post #: 93
RE: How does a brushless motor work? - 1/17/2008 10:03 PM
shinob1
Score: 100
Status: offline
Let me say it again. Outrunners do not gain additional torque from having the can and magnets spin simply due to weight. In physics torque is a measure of how much a force acting on an object causes that object to rotate. One more time, outrunners do not gain additional torque from having the can and magnets spin simply due to weight. Nor am I familiar with any sort of combustion engine that rotates around its crank shaft. Radial engines are simply pistons arranged in a circle, which connect to a central hub. The hub goes around and around (not spinning though)... Rotating the crank shaft...Not the engine... Rotary engines (Wankel) are different... As they use a spinning rotor that performs the tasks of a conventional piston engine at different times in the same housing. (That is a really vague explanation, go look it up) If its easier, a Harley two cylinder is the same concept as a radial, just two pistons. where as lawn mowers, at least mine anyway, has a rotary engine.... Do I need to delve any further?
Hide Signatures
       Post #: 94
RE: How does a brushless motor work? - 1/17/2008 11:17 PM
shinob1
Score: 100
Status: offline
oops... It would seem flat head pistons are the choice for lawn mowers...
Hide Signatures
       Post #: 95
RE: How does a brushless motor work? - 1/18/2008 4:50 AM
pilotpete2
Score: 120
Status: offline
Shinob1
The old WWI rotary engines did, in fact have the crank shaft stationary and the cylinders rotated, the prop was bolted to the crank case. Kinda like an outrunner with the prop mounted to the rotating bell.
I think you have a rotary mower, but the motor is not a rotary motor, if it's a single cylinder 4 stroke B&S, or any other motor I know of on a lawn mower, just a 4 stroke recip.
You are right about the outrunner not gaining torque due to rotational mass, the greater torque associated with outrunners is due to the magnets beig at a greater distance from the shaft center, just like when you have rusted bolt and your and you can't break it loose with your socket wrench, just add a big piece of pipe on the end of the wrench, somethings gotta give There's a high falutin tecnical term for that, but it escapes me.
Cheers,
Pete
Hide Signatures
       Post #: 96
RE: How does a brushless motor work? - 1/18/2008 7:54 AM
shinob1
Score: 100
Status: offline
That is very interesting... Yes it is a Briggs and Stratton engine. So I must have confused where the rotary aspect was applied. Sorry. And as for a rotating engine... That sounds like a bad idea for a lot of reasons. Sorry I had never heard of it before. Do you happen to know the name and or the manufacturer of it? Anyway, for future reference on the inrunner vs ourunner topic, there is an entire thread devoted to that elsewhere on this site. So back to "How does a brushless motor work."
Hide Signatures
       Post #: 97
RE: How does a brushless motor work? - 1/18/2008 8:14 PM
pilotpete2
Score: 120
Status: offline
Hi Shinob1,
I don't believe they were made in any quantity after WWI, here's a link, it has a clear explanation of the difference between radial and rotary engine. While they may look a lot alike when not running, when you see a rotary being started, there'll be no mistaking one
http://en.wikipedia.org/wiki/Rotary_engine
Now back to brushless dc motors
I can remember seeing the first Aveox sensored BLDC motors roughly 15 years ago, dang'd were they pricey and the controllers were a bit bulky, bet heck, this was roughly only 20 years after the development of brushless technology by the computer industry, don't make the mistake of confusing them with Mr. Tesla's invention, the induction motor, different fish altogether.
It would be fantastic if a cost effective way to implement this technology could be developed to replace the brushed universal (series wound) motors that power our AC powered devices around the house, such as vacuums, mixers, blenders, all your corded power tools, the list is almost endless . We have a problem with the Ozone layer now, if we eliminated brushed motors we would produce a lot less Ozone, would that make the Ozone problem better or worse, since Ozone at ground level is a pollutant. When I get a whiff of Ozone from my DeWalt drill/driver, it immediatly brings back memories of my Lionel trains, guess that makes me a geezer
Cheers,
Pete
Hide Signatures
       Post #: 98
RE: How does a brushless motor work? - 1/18/2008 11:01 PM
ron_van_sommeren
Score: 115
Last Login: 7/4/2012
From: Nijmegen/the NetherlandsNetherlands, NETHERLANDS
Status: offline
quote:
... The weight of them spinning creates a lot more torque...
Bill, inertia/mass is not responsible for generating torque/force. You need more torque to acceleratie/decelerate a spinning mass but that's a different story. However, more inertia means less torque ripple and less noise.
More distance between shaft and stator/magnet airgap is responsible for generating more torque.
Prettig weekend Ron van Sommeren
int. electric fly-in, Nijmegen, the Netherlands
brushless motor building tips & tricks
diy brushless motor discussion group
Drive Calculator download & discussion group
Hide Signatures
(in reply to bil2)
       Post #: 99
RE: How does a brushless motor work? - 1/18/2008 11:04 PM
ron_van_sommeren
Score: 115
Status: offline
quote:
ORIGINAL: pilotpete2
It would be fantastic if a cost effective way to implement this technology could be developed to replace the brushed universal (series wound) motors that power our AC powered devices ...
Christian Lucas earns his hobby money here:
http://www.magnetmotor.de/ (English available)
< Message edited by ron_van_sommeren -- 1/21/2008 11:35 PM >
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.961RCU1
