cap85king
CA, USA Status: offline
If you go onto www.wikipedia.com and search "brushless motor", they have all kinds of motor info, a lot I didn't understand, (Wikipedia has long articles). Here's the "basic" info from the site: A brushless DC motor (BLDC) is a DC electric motor that uses an electronically-controlled commutation system, instead of a mechanical commutation system. (The rest of this article assumes the reader is familiar with the principles of electrical motors.) Because of induction of the windings, power requirements, and temperature management some glue circuitry is necessary between digital controller and motor. The poles on the stator of a two-phase BLDC motor. This is part of a computer cooling fan; the rotor has been removed. B=Magnetic Flux. It is uploaded as SVG, the vektor-graphics-format, that anybody can edit.Three subtypes exist: The three-phase AC synchronous motor type has three electrical connections The stepper motor type may have more poles on the stator. The reluctance motor has all its poles on the stator, and a magnetic core on the rotor. In a conventional (brushed) DC-motor, the brushes make mechanical contact with a set of electrical contacts on the rotor (called the commutator), forming an electrical circuit between the DC electrical source and the armature coil-windings. As the armature rotates on axis, the stationary brushes come into contact with different sections of the rotating commutator. The commutator and brush-system form a set of electrical switches, each firing in sequence, such that electrical-power always flows through the armature-coil closest to the stationary stator (permament magnet.) In a BLDC motor, the brush-system/commutator assembly is replaced by an intelligent electronic controller. The controller performs the same power-distribution found in a brushed DC-motor, only without using a commutator/brush system. The controller contains a bank of MOSFET devices to drive high-current DC power, and a microcontroller to precisely orchestrate the rapid-changing current-timings. Because the controller must follow the rotor, the controller needs some means of determining the rotor's orientation/position (relative to the stator coils.) Some designs use Hall effect sensors to directly measure the rotor's position. Others measure the back EMF in the undriven coils to infer the rotor position, eliminating the need for separate Hall effect sensors, and therefore are often called "sensorless" controllers. (The BLDC motor has a trapezoidal backemf, while a brushless AC motor has a sinousoidal backemf.) BLDC motors can be constructed in two different physical configurations: In the 'conventional' configuration, the permanent magnets are mounted on the spinning armature (rotor.) The stator coils surround the rotor. In the 'outrunner' configuration, the radial-relationship between the coils and magnets are reversed; the stator coils form the center (core) of the motor, while the permanent magnets spin on an overhanging rotor which surrounds the core. In all BLDC motors, the stator-coils are stationary. [edit] Comparison with brushed-DC motors BLDC motors offer several advantages over brushed DC-motors, including higher reliability, longer lifetime (no brush erosion), elimination of ionizing sparks from the commutator, and overall reduction of electromagnetic interference (EMI.) BLDC's main disadvantage is higher cost, which arises from two issues: First, BLDC motors require high-power MOSFET devices in the fabrication of the electronic speed controller. Brushed DC-motors can be regulated by a comparatively trivial variable-resistor (potentiometer or rheostat), which is inefficient but also satisfactory for cost-sensitive applications. BLDC motors need a more expensive integrated circuit, called an electronic speed controller, to offer the same type of variable-control. Second, when comparing manufacturing techniques between BLDC and brushed motors, many BLDC designs require manual-labor, to hand-wind the stator coils. On the other hand, brushed motors use armature coils which can be inexpensively machine-wound. BLDC motors are considered more efficient than brushed DC-motors. This means for the same input power, a BLDC motor will convert more electrical power into mechanical power than a brushed motor. The enhanced efficiency is greatest in the no-load and low-load region of the motor's performance curve. Under high mechanical loads, BLDC motors and high-quality brushed motors are comparable in efficiency.
_____________________________
If you cry, and I don't see it, I'm just gonna have to make you cry again.
