RE: How does a brushless motor work?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RC Airplane Tie Down kit for your Trailer,Truck or Van - Kit
Seller:  rcjunky2
Details:   $29.99   |  4/27/2012   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> RE: How does a brushless motor work?
Page: <<   < prev  1 2 3 4 5 [6]
Tower Hobbies Today's Special Offer! Brands Products
Login
RE: How does a brushless motor work? - 2/3/2011 1:29 AM
jerrydearmond@rocketmail.com
Score: 104
Last Login: 2/10/2011
Status: offline
Glad to find that out, This was a mystery   Thanks-
Hide Signatures
(in reply to Matt Kirsch)
       Post #: 126
RE: How does a brushless motor work? - 4/16/2011 5:36 PM
band1086
Score: 100
Last Login: 4/17/2011
Status: offline
An interesting reply post from a guy in Sweden:
Quote
this switched DC changes from full + to full - instantly.
If it had said it is shifting between full + and zero instantly. It would have been DC.
But then you change polarity it's AC no matter the form of the curve! AC when you pass zero. DC when you don't reverse the electron flow. You can go to zero but not reverse the flow!
So if you only push OR drag the magnets you use DC. But if you push AND drag you use AC!
So you can use both type of waves. For DC minimum is zero and for AC it is as much negative as positive. Depend how much force you wanna have your electrons to make!
Here you can see DC on wikipedia and AC on wikipedia.
Hide Signatures
       Post #: 127
RE: How does a brushless motor work? - 5/24/2011 8:46 PM
acdii
Score: 134
Last Login: 5/22/2012
Status: offline
This should resolve all questions.
www.microchip.com/stellent/idcplg
Explains in detail how the BLDC motor works. Note it says DC, not AC.  It is 3 phase, but DC powered.  The voltage flips from + to - in relation to ground. The only part that has me a bit puzzled, 3 Phase requires 4 wires, whether it is AC or DC, the 3 phases + Neutral for AC, or ground for DC.  The ESC has only 3 wires, so where is the ground?
And yes you can push/pull with DC, pull with Positive and push with Negative. In relation to ground or zero (0). Thats how PC's work, Check out the power supplies in a computer, you have +5 v and - 5 v in relation to ground.
The PDF has all the details on the motor and controller.
_____________________________
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to band1086)
       Post #: 128
RE: How does a brushless motor work? - 5/24/2011 10:33 PM
RAULOR
Score: 100
Last Login: 5/25/2011
Status: offline
A Brushless of this type of motors for Hobbies works with a DC Input, however, the ESC does a similar function as a typical DC-AC Inverter, it creates a 3 phase AC output from a DC input. Normally a sensorless type uses only two phase for the commutation, while the third is used for positioning sensing.
There is not a "steady" ground wire here, since they are all going through zero on a sequencing bases.
The ESC besides the DC-AC conversion it also pulses and synch the waves in a timely fashion through an Oscillator and according to accel of the V.R. (Variable Resistor) and C.L.(Current Limit) set .
R.Lorenzo
Hide Signatures
(in reply to acdii)
       Post #: 129
RE: How does a brushless motor work? - 5/25/2011 12:46 AM
sky9flyer
Score: 100
Last Login: 6/27/2011
Status: offline
If it operates on a positive ground, it will only have three wires.
Hide Signatures
(in reply to acdii)
       Post #: 130
RE: How does a brushless motor work? - 6/27/2011 10:44 PM
wtjonessss
Score: 100
Status: offline
How do elec motores make sounds
Hide Signatures
(in reply to Ron v. Sommeren)
       Post #: 131
RE: How does a brushless motor work? - 6/27/2011 10:52 PM
wtjonessss
Score: 100
Status: offline
How do elec motors make sounds and music ? I have a JR and the TX beeps and the elec motor beeps also and at the same time as the TX beeps !
This has been bugging me for a long time "
How do they do it ?
wtjones8@yahoo.com
Thanks much, Wally
Hide Signatures
       Post #: 132
RE: How does a brushless motor work? - 11/6/2011 10:12 PM
larrytoo
Score: 100
Last Login: 11/19/2011
Status: offline
Will a single ESC control two non interconnected outrunners?    Just a beginner (to outrunners) here, but I doubt it. As I see it, it would be virtually impossible for both motors to see the same prop load so current would not be even between them and the phase of the "sensing" wave form from each would differ.  Since this would be combined, I would think at best that the ESC would be VERY cornfuzzeled!
Larry
Elsewhere on this site I posted a cry for help with connections and "programming" an ESC.
Hide Signatures
(in reply to A TRAIN)
       Post #: 133
RE: How does a brushless motor work? - 11/6/2011 10:36 PM
larrytoo
Score: 100
Status: offline
How does one measure the current and power use of an outrunner?  Can one just meter the battery wire to the ESC (yes, there would be some esc load and some xcvr/servo load)?
How is it that outrunner speeds are given in rpm/volt (unloaded)?  Does the ESC sense the input voltage and use that to limit the motor speed?
I'm trying to understand/program/use a Gunther BG (1400Kuv, 25A, 240W) outrunner with a Dymond Futur(E) ESC but have no instructions (and NO help from the supplier in Homestead Fla (posting his replies to my questions might constitute a FLAME!)).  Stick programming of timing, throttle, brake, autocutoff, cutoff, soft start is claimed, but how  do I do it?????
Can anyone be of assistance?
Hide Signatures
(in reply to larrytoo)
       Post #: 134
RE: How does a brushless motor work? - 11/6/2011 10:42 PM
larrytoo
Score: 100
Status: offline
Sure, the v-tail mixer could be used to trim the two motors to nul out any residual (drag inducing) rudder angle when not turning.  May also be a lower drag solution when making wide turns or small course corrections.  (I once, in a past life, conned a cruiser with one shaft locked, used differential RPM's on the other three shafts to aid in steering).
Larry
Hide Signatures
(in reply to Stokes)
       Post #: 135
RE: How does a brushless motor work? - 2/2/2012 6:40 AM
scott88-RCU
Score: 100
Last Login: 2/2/2012
Status: offline
I'm glad to see that this post is still up! Haha it's been a while...
Scott
Hide Signatures
       Post #: 136
RE: How does a brushless motor work? - 2/18/2012 8:52 AM
chuckk2
Score: 100
Last Login: 5/23/2012
Status: offline
Motors may be Y or Delta.
Hide Signatures
(in reply to scott88-RCU)
       Post #: 137
RE: How does a brushless motor work? - 4/15/2012 9:54 PM
tootalltechie
Score: 100
Last Login: 5/20/2012
Status: offline
I was thinking of using a brushless DC motor as a starter motor on a G26 zenoah instead of the pull start. Any idea how and what size of motor I would use. Also if I connect straight to the shaft, any harm in letting it run no current when motor is running?
Hide Signatures
(in reply to chuckk2)
       Post #: 138
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
0.281RCU1
