taildraggerdave
CA, USA Status: offline
Yes and thanks. Rare Bear is right. My plane is balanced exactly on the book mentioned CG and it flies superb. I would not change the CG that I currently have for any reason. The stock retracts work excellent so unfortunately, Cruz, it is probably a setup problem on your retracts. You want to make sure that when the gear is down and locked, the rod is pushed (or pulled, I don't remember) all the way into the locked position. If your servo doesn't travel enough or whatever, let the slack be on the gear up side of the stroke. Come on guys, let's get these things in the air........
_____________________________
NOMADIO TEAM 007 2006 NATC Sportsman 5th Scale Champion
