mnmills2 -> RE: World Models .60 size P-51 Mustang--Petie 2nd version (8/2/2004 7:32:10 PM)
I didnt get a chance to hit the flaps. I was about 30 feet on the upwind side at 3/4 throttle. I had just pulled the gear up as things were starting to go well. I was just really relieved when it came back down and worked as advertised. These are my first mechanical retracts Ive owned. I didnt have to add any weight to balance it... it was perfect. I hit the gas on takeoff and the tail came up quick so pulled back on the elevator. The controls were so sensitive, it almost went vertical from there. Then I pushed forward to get some speed, and it did a nose dive down to a foot off the ground. I pulled back again and climbed away and shifted to low rates and everything was perfect. I highly recommend 50% of the recommended throws. I took the advice and coated the retract wells with epoxy. I actually used a mixture of 30 minute epoxy and denatured alcohol to thin it down. With a thinner mixture I was able to get it to wick into a few corners. Mine didnt break off on the maiden voyage! One thing I did was I screwed up my cowl in the building process. I mounted the engine mounts upside down. Its sounds weird...but the mounts are a little different than anything I had seen. THis caused my motor to be mounted 3/4" off center with out me realizing it. THen I cut the dummy cowl to fit and traced it on my final cowl and started hacking away. It still doesnt look too bad, the hole is just a little large. I called airborne models and they have already shipped me a new cowl. I had good luck with them. Im using the 91FX in mine. Ive never used a fuel pump before. I ended up with only a 14oz (414cc) tank. Is this too small? I may have just been out of gas. I quickly refueled and didnt end up flying again so Im not sure if the tank was completely empty. The manual says that is sufficient, but I was running it pretty rich and I only got about 5 minutes out of it. I just read the post above saying 24oz and I started to wonder.
