taildraggerdave -> RE: World Models .60 size P-51 Mustang--Petie 2nd version (11/2/2004 1:06:20 AM)
On the control throws, I believe I cut what they said for the ailerons and elevator in half. The flaps are set just until they bind against the wing--but not quite. At the speeds that we fly at, control throws can be kept to a minimum. I'm using about 1/4" on the ailerons and no more than 3/8" on the elevator. I run the rudder up to the stops also. I set the CG exactly where the book said. To me, this plane is the absolute best Mustang I have flown. I hope a change in setup yields a better flying plane for you, too.
