bbuss
WA, Status: offline
I now have several flights on mine after buying a new wing. On only the second or third flight, I don't rightly remember which, I got the landing wrong and it ripped the retract and half of the guts out of the wing. I got a new wing from AB and epoxied it good all around the mount area and it has survived some of my not-so-good landings. I am flying with a Magnum 91 running a 14x6 Master and it is great. I set the control throws to 50% the recommended, with a lower dual rate setting and 25% expo and it handles great. With the 40 degree flap extension (physical limit of travel) you can grease the landings. I am using the standard tank and have increased the timer on my radio from 10 to 12 minutes and I still have fuel left, and the tank is in the normal position. It balanced on the money with the battery mounted in front of the tail servos with no added weight, but I am not using the supplied spinner. I replaced it with a Tru-Turn and painted it to match the blue nose. It is becoming a favorite with me, to the detriment of my other warbirds !!!
