RE: Combat Models F-16
Tower Hobbies
Logged in as Guest
Users viewing this topic: fly4food18
  Printable Version
More Resources on the
A-10 Warthog
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Combat Models F-16
    Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
    Login
    RE: Combat Models F-16 - 8/24/2004 1:11:59 AM
    vicman
    Status: offline
    Dave, is yours the pusher or puller? My instruction book is for the puller.
    _____________________________
    Bigger Badder Meaner Faster!
    Revver Brotherhood & NMPRA #41
    (in reply to Dave03B)
           Post #: 26
    RE: Combat Models F-16 - 8/24/2004 2:18:27 AM
    Razor-RCU
    Status: offline
    2 diff. planes fellas--
    Tractor- MVVS will rock!
    Pusher- YS-45, Macs 7.5/8.5 10x7-8apc
    I have had both, now I want the F-15
    Revver #5
    (in reply to vicman)
           Post #: 27
    RE: Combat Models F-16 - 8/24/2004 5:30:22 AM
    flyordie
    Status: offline
    Hi Guys , I guess now that I have the F-16 Tractor kit I should chime in. I have heard that the tractor kit SCREAMS with an OS .32SX!!!!!!!!!!! As for the Pusher , the YS 45 is the best way to go. I have the CBM A-10 w/ the YS 45 pusher and that monster pushes like a .61!!!!!! Lots of posts on RCU about different configurations,(pipes ,engines,props) I'm looking forward to getting mine started soon. (I'm shy the assembly manual , but VICMAN is gonna help me out)
    (in reply to Razor-RCU)
           Post #: 28
    RE: Combat Models F-16 - 8/24/2004 5:48:58 AM
    Razor-RCU
    Status: offline
    I wanna say that my tractor (smaller) F-16 was powered by an OS-45FSR??? It was pretty fast for me in 1994 (?)
    Revver #5
    (in reply to flyordie)
           Post #: 29
    RE: Combat Models F-16 - 8/24/2004 9:01:14 AM
    Dave03B
    Status: offline
    Mine is Pusher
    Dave Bright - www.wimbornemac.org
           Post #: 30
    RE: Combat Models F-16 - 8/24/2004 11:57:07 AM
    vicman
    Status: offline
    Dave, do you need a manual also or just info?
           Post #: 31
    RE: Combat Models F-16 - 8/24/2004 12:00:25 PM
    Dave03B
    Status: offline
    info really, but if you have a manual scanned that you could email? that would be great appreciated.
           Post #: 32
    RE: Combat Models F-16 - 8/24/2004 12:23:59 PM
    vicman
    Status: offline
    PM me with your e-mail addy.
           Post #: 33
    RE: Combat Models F-16 - 8/24/2004 12:27:12 PM
    vicman
    Status: offline
    By the way I would like to thank Angel and Jack for their help on getting me a video!
           Post #: 34
    RE: Combat Models F-16 - 8/24/2004 12:37:39 PM
    Dave03B
    Status: offline
    u have mail
           Post #: 35
    RE: Combat Models F-16 - 8/25/2004 4:41:55 AM
    angelrcdesign
    Status: offline
    I'AM GLADE TO BE OF SOME HELP VICMAN.
    IF YOU CAN FIND A OLD BYRON TUNE PIPE ,IT WORKS GREAT.
    ALL YOU HAVE TO DO IS CUT OUT BETWEEN THE TWO FIN ON THE BOTTOM OF THE F-16.
    I CUT OUT A SQUARE 3", THAN BRACE IT UP, I USE A 1/8 PLY. MAKE A BRACKIT BOLT IT TO THE PLY. THEN EXPOZY TO THE HATCH.WITH THE ENG. OUT SLIP THE PIPE THROUGH THE BODY SIT IT IN THE BRACKIT ITS A LITTLE TIGHT BUT YOU'LL BE ABLE TO LOOSEN IT UP OR TIGHT, AND DO YOUR REPARES. PUT HARD WOOD IN THE CONERS. THEN CLOSE IT UP USEING THE FOUR SCREWS ON EACH CORNERS. DID YOU GET THE PIC.
    If something fails,try and try again until you get it right.
           Post #: 36
    RE: Combat Models F-16 - 8/25/2004 5:21:07 AM
    p4725re
    Status: offline
    i have the cbm f16 and powerd it with a fx61 with a performance speciaties pipe
    a bolt of lightting is how it performend i did mine in the mig colors and my buddy
    did his in the farbanks alaska colors and we combat flew with these all was needed
    for take off was about 10 feet and to land we used air brakes and lots of new tires
    about a set a month and a hundred feet of paved runway i got bord with mine
    and donatined it to the rotc school here in alaska
    you guys will have fun
           Post #: 37
    RE: Combat Models F-16 - 8/25/2004 8:37:40 AM
    Dave03B
    Status: offline
    So what sort of performance can i expect with the YS 45? scale speed? vertical?
    (in reply to p4725re)
           Post #: 38
    RE: Combat Models F-16 - 8/25/2004 4:57:12 PM
    Razor-RCU
    Status: offline
    Dave, you go now! Please refrain from posting in this forum until we have proof that you mounted the West on your Magnum...
    Are we talking about the pusher again or tractor?
    I have a Patriot arf but I am going to start with a McCoy-19 (per Dave's advice-) until I get used to the speed...
    Revver #5
           Post #: 39
    RE: Combat Models F-16 - 8/25/2004 6:23:53 PM
    Dave03B
    Status: offline
    you are living dangerously Razor! and yes that is a threat
