vicman
NC, USA Status: offline
Razor has the pipe, but he seems to be distracted while harrasing Dave from across the pond . I fitted a 6 up tonight, the length is ok but I will need to carve a little out in the main fuse. I plan to get the motor all situated before I go permanent with the tank. I have a pump but bu the look of things I don't think I will need it. (that ought to get James' attention). James, if you are loitering near here you should change your sig to reflect your un-official censorship of the speed prop plane forum in honor on your abuse to Dave. Razor's proofreader
_____________________________
Bigger Badder Meaner Faster! Revver Brotherhood & NMPRA #41
