ND_newbie
ND, USA Status: offline
Bert is exactly right. In the reading I have done about the actual aircraft, both engines are tied into a transmission system that automatically transfers the load of both props to the left engine, if the right engine fails, and vice versa. I would think that this would be an absolute necessity, just to balance the lift of the engines, if they are not exactly speed synchronized, but I have to leave that theory to the aeronautical engineers. Would the aircraft be controllable, at all, if one of the engines cut out, if no means of transferring the load was in place? I think this will be an incredible aircraft, if it comes to fruition. Great discussion, and good luck to you, Noah! Mitchell
