Diesel Fuel Handling
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Diesel Fuel Handling
Page: [1]
Login
Diesel Fuel Handling - 6/10/2002 4:58:49 PM
RCPAUL
Status: offline
I received a diesel engine for Christmas and just got a gallon of fuel. Some questions on handling the fuel:
Is it advisable to divide the fuel into smaller containers. If so, any recommendations what kind and where they can be obtained.
How do you transfer the fuel from can to tank - fuel bulb, pump, etc.
How long will a gallon last in the can?
If I need to add ether and use John Deer starting fluid, how do I get the ether from the starting fluid can to the fuel?
Any help will be appreciated.
RCPAUL
       Post #: 1
Adding Ether - 6/11/2002 9:19:44 AM
pcjohnson_ohio
Status: offline
Freeze the can of ether, then either spray into an empty container or turn the can upside down, release the propellent, open with a can opener and pour.
You need a metal can with a tightly fitting cap to store the ether in. I use an 8 oz. plummers solvent container ( the "cleaner" which is MEK + Acetone, emptied of course ) and seal the lid with teflon tape.
I think people use a closed system for transfer.
ie a metal cap with two brass tubes soldered, so fuel can be transferred without uncapping. Connect the two tubes with a short piece of fuel line when not in use. The shorter the better, because apparently the ether leaches through plastic as well. Tightly capped the fuel will last, uncapped ???
I mix my fuel as I use it, in a 100cc urine specimen cup for smaller amounts and a 16 oz. smoke tank for larger amounts
Pete
(in reply to RCPAUL)
       Post #: 2
Diesel Fuel Handling - 6/13/2002 4:38:54 PM
BALSA BANDIT
Status: offline
Many moons ago when my dad and brother were into modeling, we had lots of diesel engines and we mixed our own fuel. we always sealed ether and nitro with butrate dope. Ken....The "BALSA BANDIT"
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
