William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
Volfy: Hydrate, Hydraulic, and hydrogen come from the same root. The only one of the three that means water is involved is hydraulic, although modern hydraulic actuating systems don't use water. The first hydraulic brakes on cars, though, actually used water as the working fluid. Ethyl alcohol that we drink, and methyl alcohol that we burn, are both carbohydrates. The word fraction "Hydrate" means the compound has hydrogen and oxygen in it, but not in the form of water. There are also Hydrite, and hydride, the different forms have to do with the number of oxygen atoms in each molecule. Now if you say "Hydro," then whatever it is has water involved, but water isn't part of the compound. Hydrocephalic, for example, means water on the brain. You also have "Tincture" which means alcohol is the liquid. "Tincture of Iodine," for an example here. Maybe we could say you're "Tincto-Cephalic" when you're drunk. Haw. Anyway, thus endeth the lesson for today. Bill.
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
