speeddemon32
Joined: 3/1/2004 From: San Bernardino, CA, USA Status: offline
try drawing the flames on the outside of the body first with a Sharpie marker (ONLY IF THERE IS A PROTECTIVE COVERING) if you mess up, the wipe it off with water, and A rag. when you are satisfied with the flames outline, then you can do one of two things. 1) try and follow the flames with masking tape (hard to do, and usually does not do well with curves) 2) mask the entire inside (tape, or liquid mask), and cut with a NEW razor what you want done. (cut the flames out) just donut cut to deep, you will wind up weakening the body, and it will crack on a heavier impact. there is always a 3rd choice.... have someone do it for you. (like me) anyways, let me know how it turns out. P.S. as for the drawing the actual flames..... try to print something off of the internet to trace. or find a friend that can draw them on for you. ( i think this is more what you were looking for, as far as your question goes. )
