castor
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> castor
Page: [1]
Login
castor - 3/5/2004 10:17:21 PM
Veco
Status: offline
Hi; I am running a 20% castor syn. mix fuel and I want to boost the castor oil content to make the oil content 23%. Does anyone know how to figure how much castor to add to one gallon of fuel to bring up the oil content to 23% ? Thanks
       Post #: 1
RE: castor - 3/5/2004 10:25:34 PM
splatt
Status: offline
128 oz. in a gallon.... 12.8 oz. would 10 % 1.28 would be 1 %
1.28 x 3 = 3.84
My brain would say add alittle less than 4 oz. and you'll be there. But than again I don't rely on my math to save my life
(in reply to Veco)
       Post #: 2
RE: castor - 3/5/2004 10:26:17 PM
splatt
Status: offline
I'm doing the same thing. I got a MDS .78 for 60 bucks from the LHS and the "theys" of the world say to have a higher caster content for these russian engines. So I got some caster to add to my mix too, makes 'um run alittle cooler since castor can carry the heat out the exhaust pipe. Just alittle messy
< Message edited by splatt -- 3/5/2004 10:32:42 PM >
(in reply to Veco)
       Post #: 3
RE: castor - 3/5/2004 10:44:48 PM
Veco
Status: offline
Thanks, I will add around 3 1/2 oz. per gallon
(in reply to splatt)
       Post #: 4
RE: castor - 3/12/2004 4:08:56 PM
XtremeNitro
Status: offline
by adding oil to the gallon u no longer have a gallon of fuel. a gallon is 128 oz and if u add 3 or 4 more ounces u have 131-132 oz which makes all the percentages of the fuel wrong on the bottle. u may want to consider this. between 20-23% oil it won't make a difference if it is a good quality oil. i market my own fuel and for planes i run 12%, heli's 18% and cars 8% and most engines i have seen do more than 6 gallons of fuel. my own personal engine runs on 6% oil and it has 9 gallons thru it so far and still going.
(in reply to Veco)
       Post #: 5
RE: castor - 3/12/2004 4:11:31 PM
rajul
Status: offline
quote:
ORIGINAL: Veco
Try using Klotz Benol castor oil, if you can get your hands on it. It's the best there is
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to Veco)
       Post #: 6
RE: castor - 3/16/2004 7:58:48 PM
hauckf
Status: offline
Xtreme is right about the calculation. To increase the oil content from 20% to 23%, you would need to add 5 oz of oil, not 3.5 oz. The formula for calculating it yourself is as follows: Oz of oil to add to one gallon of fuel = (D%-S%) x 128/(100-D%), where S% is the starting % oil, D% is the desired %. In your example, 3x128/77=4.99. I agree Rajul about Benol too.
(in reply to rajul)
       Post #: 7
RE: castor - 3/20/2004 3:18:12 AM
jessiej
Status: offline
Or if you don't want to do the math go to www.nitrorc.com. Click on Custom Blending Workshop. At the bottom of the page is a realy neat program that allows you to come up with any % of oil, nitro etc. by simply plugging in a few numbers.
jess
(in reply to hauckf)
       Post #: 8
RE: castor - 3/20/2004 3:46:32 AM
rajul
Status: offline
Nothing like deriving equations from first principles
< Message edited by rajul -- 3/19/2004 10:46:53 PM >
Mike Marks
RCU Moderator
(in reply to jessiej)
       Post #: 9
RE: castor - 3/20/2004 1:44:54 PM
Veco
Status: offline
That is a nice little program on the nitrorc.com website. It makes adding oil to your fuel a snap, thanks
(in reply to rajul)
       Post #: 10
RE: castor - 3/21/2004 4:28:39 AM
jessiej
Status: offline
quote:
ORIGINAL: Veco
I got my fill of equations in college, back in the day of the slide rule. I'll take the easy way out every trip of the train.
(in reply to Veco)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.125RCU1
