Hitec 81 and 81 MG servos are they really cheap??
Tower Hobbies
Logged in as Guest
  Printable Version
JR XP9303, Spektrum Mod., and Receivers
Seller:  beams
Details:   $475.00   |  6/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Hitec 81 and 81 MG servos are they really cheap??
Page: [1]
Login
Hitec 81 and 81 MG servos are they really cheap?? - 3/8/2004 2:19:46 PM
Zafer
Status: offline
Hi everybody,
I have a complaint to make. My Hitec 81 servo on the ailerons stripped a gear and caused a crash . İt was the first flight of my new SPAD.
I was using H81MG on rudder and on elevator and H81s on trott. and ailerons. All in all I have 10 Hitec 81 + 81 MGs.
I have also another complaint about Hitec servos. Whenever I used them at least one of them is moving aimlessly and making sound.( It is not that because I put Tx very close.) I never have problems with Graupner (JR in USA) servos. The reason that I bought Hitec stuff ?? Because they were cheap. But I will never buy Hitec servos again. ( I have no problems with Hitec receivers )
I have just come to a conclusion that, I am not that rich to use the cheap ones. ( I believe Sir W.Churchill said that first)
I just want public knows about this.
Regards. And sorry for the language mistakes.
Zafer
       Post #: 1
RE: Hitec 81 and 81 MG servos are they really cheap?? - 3/9/2004 10:07:07 PM
MikeMayberry
Status: offline
Since there is not a Graupner servo that is in the same price catagory as the HS-81, you can't really compair apples to apples here. You might want to try our HS-85's which are a higher end model in the same size case. You might also keep an eye out for the new Multiplex Polo servo which is a similar size but digital!
Mike.
(in reply to Zafer)
       Post #: 2
RE: Hitec 81 and 81 MG servos are they really cheap?? - 3/9/2004 11:32:47 PM
lrb75
Status: offline
I have several hs-81 in my 1/2a racers and have stripped one in a crash. I also stripped a hs-85 and and hs-605 in a crash. I fly almost all hitec servos and receivers and have never had a problem with their products except after a crash that was my fault. Chances are your stripped servo was due to flutter or the crash.
< Message edited by lrb75 -- 3/9/2004 11:34:06 PM >
(in reply to Zafer)
       Post #: 3
RE: Hitec 81 and 81 MG servos are they really cheap?? - 3/10/2004 1:14:49 AM
mglavin
Status: offline
You might consider that you're not using the right tool for the job. The HS-81 is considered a MICRO servo, with the nylon gears its not comparable to larger more robust servos even if the torque rating is in line.
How big is your Spad? Weight, motor and aileron sizes would help ascertain the viable application of the HS-81 micro servo.
Have you considered flutter as the root cause of the aforementioned gear-train failure?
It's possible you damaged the servos gear-train subsequent to crashing the model.
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to Zafer)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
