RE: Robbe PT 15 Patrol boat review
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> RE: Robbe PT 15 Patrol boat review
Page: <<   < prev  1 [2]
Login
RE: Robbe PT 15 Patrol boat review - 10/3/2006 7:46 PM
Temps
Score: 100
Last Login: 10/15/2009
Status: offline
i belive the motor is a power 800 motor but it came as a fitting kit with the gearbox prop tube and screw the combination makes for ample power and speed and duration
_____________________________
Quattro/0/Floor/3/Trees/0/Water/5/
Hide Signatures
(in reply to martno1fan)
       Post #: 26
RE: Robbe PT 15 Patrol boat review - 7/18/2009 6:30 PM
LittleDJ
Score: 100
Last Login: 8/6/2009
Status: offline
I av jus got my hands on a PT-15 this will b my 1st build lol so if any1 as any advise plz feel free 2 contact me n if i get stuck i hope thr sum1 on here that can help me
Hide Signatures
(in reply to Temps)
       Post #: 27
RE: Robbe PT 15 Patrol boat review - 7/31/2009 8:33 PM
deggmorgan
Score: 100
Last Login: 8/3/2009
Status: offline
I have also been given a PT 15 but without the construction plan.Do you have a copy - can you help?
John Morgan
Hide Signatures
(in reply to LittleDJ)
       Post #: 28
RE: Robbe PT 15 Patrol boat review - 7/31/2009 9:49 PM
Temps
Score: 100
Status: offline
go to robbe i belive they do an adobe copy for download
Hide Signatures
(in reply to deggmorgan)
       Post #: 29
RE: Robbe PT 15 Patrol boat review - 8/1/2009 9:42 AM
deggmorgan
Score: 100
Status: offline
Many thanks but sorry to appear hopeless - I cannot seem to find a contact e mail etc for Robbe can you help?
Hide Signatures
(in reply to Temps)
       Post #: 30
RE: Robbe PT 15 Patrol boat review - 8/1/2009 7:14 PM
Temps
Score: 100
Status: offline
www.robbe.com think you may need to register to get instructions
Hide Signatures
       Post #: 31
RE: Robbe PT 15 Patrol boat review - 8/1/2009 8:00 PM
deggmorgan
Score: 100
Status: offline
Very grateful.Thank you.
Hide Signatures
(in reply to Temps)
       Post #: 32
RE: Robbe PT 15 Patrol boat review - 8/16/2009 11:46 PM
rowdyates
Score: 100
Last Login: 10/31/2009
Status: offline
I'm also building one of these at the moment, bought it a few years ago but never got around to building it. I'm about to start painting and have some acrylic primer to start off, I'm assuming I would then also need acrylic paint for the top grey coat, for the detail would I also need acrylic or can i use Humbrol enamels, I have a few of these lying around from other models, but I'm not sure you can mix the different types of paint.
Also for the electrics, anyone know how to wire them up, tried searching but can't seem to find any info.
Keith
Hide Signatures
       Post #: 33
RE: Robbe PT 15 Patrol boat review - 8/17/2009 8:37 PM
Temps
Score: 100
Status: offline
enamel and acrylic will react try just using one type my hull and super structure is sprayed in two different colour primers then all satin coated
Hide Signatures
(in reply to rowdyates)
       Post #: 34
RE: Robbe PT 15 Patrol boat review - 8/17/2009 9:07 PM
rowdyates
Score: 100
Status: offline
OK, my plan is to use a primer from Halfords which is a plastic filler primer, I should then be ok to use the Humbrol acrylic spray cans on top of this would I. Unfortunately I don't have a spray gun and am limited to cansand figured to get the colours I would need to use the humbrol ones?
Keith
Hide Signatures
(in reply to Temps)
       Post #: 35
RE: Robbe PT 15 Patrol boat review - 8/17/2009 9:38 PM
Temps
Score: 100
Status: offline
If you look at the pics i used halfords filler primer on all parts first then grey primer for the hull with red oxide primer for under the waterline.The super structure was also grey primer from rattle can then flattend it with 1200 grit paper then just halfords satin laquer to achive the finish the deck is sprayed in rover hurrican greay again with satin laquer on top i have another gun boat pic i made last year using the same teq
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 36
RE: Robbe PT 15 Patrol boat review - 8/18/2009 12:29 AM
rowdyates
Score: 100
Status: offline
thanks for that, never thought about just leaving the primer as the colour then covering with a clear coat
what did you do with the windows on the bridge, did you leave them clear, I assume I would have to mask them to do this, seams a bit fiddly. Alternative would be to just paint them in later.
Keith
Hide Signatures
(in reply to Temps)
       Post #: 37
RE: Robbe PT 15 Patrol boat review - 8/18/2009 9:55 PM
Temps
Score: 100
Status: offline
I masked the windows then freehand painted the frames i have also seen other people cut the windows completely out then put clear plasticard inside after painting
Hide Signatures
       Post #: 38
RE: Robbe PT 15 Patrol boat review - 8/19/2009 12:05 AM
rowdyates
Score: 100
Status: offline
Thanks again, will look to mask my windows, had a look in Halfords today, could only see one clear laquer but it wasn't satin, didn't have time to ask anyone, will try again, but saw the grey and the oxide one.
Did you wire up your lights in your build?
Keith
Hide Signatures
(in reply to Temps)
       Post #: 39
RE: Robbe PT 15 Patrol boat review - 8/19/2009 6:35 PM
Temps
Score: 100
Status: offline
yes all lights work i used a separate switch and a 4.8v battery pack
Hide Signatures
       Post #: 40
RE: Robbe PT 15 Patrol boat review - 8/21/2009 6:12 PM
rowdyates
Score: 100
Status: offline
Hi me again,
Started to do some of the painting today, boy you think youve sanded it smooth, then that first bit of paint shows so many imperfections.
Managed to get some oxide and grey primer from halfords, they say they don't do a satin laquer, so there is only one a clear laquer, reading the instructions on it I get the impression that it will leave a gloss finish, if I were to use this could I use fine sandpaper to take the gloss off or should I look for some other make, not really sure what to do here for the best.
Keith
Hide Signatures
(in reply to Temps)
       Post #: 41
RE: Robbe PT 15 Patrol boat review - 8/21/2009 11:22 PM
Temps
Score: 100
Status: offline
i get all my paint from halfords the satin cote stuff is called Plasti-kote Super Enamel Satin Clear Acrylic 400ml this was taken from the halfords website http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_163303_langId_-1_categoryId_165495
Hide Signatures
       Post #: 42
RE: Robbe PT 15 Patrol boat review - 8/21/2009 11:46 PM
rowdyates
Score: 100
Status: offline
Ahh, I was thinking it was a Halfords own make, that makes sense, yeah I saw the plasti-kote stuff, I'll give that a try.
Keith
Hide Signatures
(in reply to Temps)
       Post #: 43
RE: Robbe PT 15 Patrol boat review - 8/24/2009 10:05 PM
rowdyates
Score: 100
Status: offline
OK, so I've done my grey bits, hopefully some nice weather tomorrow and I'll get the oxide painting done, then I can laquer, couple more questions if I may.
The transfers, is it best to put these on before any laquer or after say one coat, I read somewhere that you can sometimes see the edges of the transfers, or because I'm putting on laquer anyway does it not matter, I noted you put your on before any laquer.
Also not really looking forward to doing the railings, any advice for those, especially the painting, did you construct yours on the boat itself or elsewhere, just worried that if you have to paint them on the boat then I'll get paint everwhere.
Keith
Hide Signatures
       Post #: 44
RE: Robbe PT 15 Patrol boat review - 8/24/2009 10:21 PM
Temps
Score: 100
Status: offline
put transfers on before laquer or they will look shiny the railings were assembled on the boat and painted after i found them easy compared with my trent life boat . as for painting i painted my railings free hand just dont overload your brush
Hide Signatures
       Post #: 45
RE: Robbe PT 15 Patrol boat review - 8/24/2009 10:25 PM
rowdyates
Score: 100
Status: offline
Thanks, I assume you used the same primer for the railings as the rest of the boat?  Just read your review for the lifeboat as it happens and yes the railings there look a bit daunting.
Keith
Hide Signatures
(in reply to Temps)
       Post #: 46
RE: Robbe PT 15 Patrol boat review - 8/24/2009 10:27 PM
Temps
Score: 100
Status: offline
yes i used the same colour what i did was to spray some of the primer into an old pot as its primer its quite thick and paints on easy and dries really quick
Hide Signatures
       Post #: 47
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.172RCU1
