Richard L.
Joined: 7/28/2002 From: Redmond, WA, USA Status: offline
quote:
ORIGINAL: F4U Killer The Bad part about it is they don't fit my Kyosho Corsair. They are heavy duty and impressive. But they don't fit. If the retracts don't fit because the struts are too long, then they sent you the wrong ones. However, if they don't fit because the base housings are too wide, then it's YOUR problem. These ARF's are designed to accept mechanical retracts, so no matter what brand of air retracts you buy (Spring Air, Robart, etc...), you will need to widen the mounting rails. In the case with ARF's that require rotating retracts, such as Hellcat, Corsair, P-40, you will also need to glue in mounting blocks. Rotating air retracts will not drop straight in without modifications.
