Superbike
Help!! My trusty Sirio.18 just bit the dust after seven gallons of 30%. I went online and saw this new picco P2. I had to have it! Just got it Wed. of last week. This thing has been nothing but a headache. No matter how you try to tune it, this engine will not pull from the bottom end. I called Werks racing and they told me that most of the time they hears this complaint it is the clutch engaging too early. I have now tried just about every combination of clutch MIP high stall, aluminum high stall, etc. The higher stall helps hide this problem a little bit but not a single clutch could hold up to the power/higher rpm stall. They all would start to slip after half a tank. The only clutches that would not start to slip is the regular stall clutch. This puts me back to the engine bogging real bad on the bottom end and then hitting real hard on the top. Now before any of you ask if I know how to tune an engine I will go ahead and say that I have been doing this for years and that is not the problem. This engine definitely has a problem. Air leak?Maybe? I do not know but I definitely need some help!! Please anyone, I do not know what to do.
