flysalvo
Joined: 2/1/2004 From: Lagrange, KY, USA Status: offline
Larry S, Just thought I would update this post with my progress with my Sea Fury and the weave filling and sanding. The cheap auto primer I was buying had no building properties to it, the light weight spackle was a lot of work (applying and sanding, applying and sanding), so I went to the local auto parts store that just so happens to specialize in auto paints and bondo and fiberglassing equipment. They had a high build primer that I thought I would give a try, problem is, it is 15.00 bucks a can. I dont know about you fellas, but I spray, sand, spray, sand and then do it all over again, I like to have my scale panel lines embossed in my primer. Good primer, but expensive. I decided to give the Krylon primer/sealer at Wal Mart a shot. Less than 3.00 bucks a can. The filling and building qualities of this primer are so superior to all the other methods I have tried I can't imagine "not" using it again on my next model. It sands beautifully as well! Thanks again for the tip Larry. I hope that this thread helps another fledgling builder as much as it has helped me. Oh, and by the way, fiberglassing a sheeted model is so totally worth the time and effort. It isn't as difficult as one would be convinced of by other builders. If done properly, the added weight to the aircraft is minimal, but the appearance, well, it can't even be compared to film coverings.
