Quicksilver
Joined: 7/27/2006 From: Oneonta, NY, USA Status: offline
first of all, you dug up a 2 yr old thread, which of course I read all the way to my own 2 yrs old reply. but aside from that, a jet unit really should be easier than an outboard in saltwater. Mainly because the outboard is never really sealed, wires must come out of the cover, salt water can get in and if you didnt remove the cover and clean the "powerhead" every time, you'd ruin it in no time. A jet unit is 90% plastic, uses a stainless steel shaft, plastic impeller and a brass stuffing tube. I dont even think you really would need to rinse out a jet for any reason other than seaweed getting in. With any electric boat the main concern is going to be whether or not water is entering into the electronic and motor area. With electrics saltwater wont affect the cooling system, unless by some strange reason you use steel pipes or are use a water jacket instead of a simple coil. Gas/nitro boats are a whole different ball game. Personally with those I wouldnt take the risk unless of course you could simply accept the risk and take all necessary steps to ensure you dont ruin the motor.
_____________________________
Game''s over, losers! I have all the money. Compare your lives to mine and then kill yourselves. -Bender
