AFP Question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> AFP Question
Page: [1]
Login
AFP Question - 3/12/2004 6:52:49 AM
3DDEAN
Status: offline
I am running AFP with the Real Flight Controller.
I am flying the OMP YAK54P.
How do I set up duel rates and elevator-flap mixing?
Is elevator-flap mixing needed on the sim?
I tried setting the elevator-flap mix up on my Futaba radio, but I could not get both ailerons to move in the same direction with the mix on. Has anybody got this to work?
Dean
< Message edited by 3DDEAN -- 3/12/2004 7:36:52 AM >
       Post #: 1
RE: AFP Question - 3/12/2004 12:31:15 PM
STLPilot
Status: offline
I have not tried that, however I have gotten spoilerons and flaperons to work. I have also got some mixes going no problem. I've never mixed ele-flaps, but it sound like you must assign the flap channel to the proper channel in AFP controller setup. Have you done that?
_____________________________
Here At The Wall
(in reply to 3DDEAN)
       Post #: 2
RE: AFP Question - 3/12/2004 3:35:13 PM
3DDEAN
Status: offline
I have aileron on channel 1, flaps on channel 6. I turn Flaperon on and that works fine.
I turn ele->flp on and the right and left aileron do not work together.
       Post #: 3
RE: AFP Question - 3/12/2004 4:33:53 PM
STLPilot
Status: offline
I'm stumped ... it should work, prolly just missing one small detail. Keep messing with it. Should work. Not 100% sure though.
Here At The Wall
       Post #: 4
RE: AFP Question - 3/12/2004 7:38:24 PM
MAWRC 1
Status: offline
It may be your physical setup.
Do you have it configued as one servo (channel) per aileron or one servo (channel) for both ailerons? It sounds like the later since you said ailerons on channel 1. If you only have one servo (channel) for both, it will never work since the ailerons must be controlled independent of each other.
Regards,
MAWRC 1
(in reply to STLPilot)
       Post #: 5
RE: AFP Question - 3/12/2004 10:27:14 PM
3DDEAN
Status: offline
I have it set up like I have all my fun fly planes, with one servo per aileron.
As I said, the Flaperon mix works fine. When I turn on ele-flap mix, the two aileron servos go in opposite directions.
Has anybody got the ele-flap mix to work?
       Post #: 6
RE: AFP Question - 3/13/2004 1:11:54 AM
rajul
Status: offline
Dean, register yourself with the IPACS forum where you can communicate directly with the creators and experts of AFP on any questions that you have http://www.ipacs.de/cgi-bin/ultimatebb.cgi They might be able to give you suggestions and a solution
Good luck !
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
       Post #: 7
RE: AFP Question - 3/13/2004 11:56:47 AM
STLPilot
Status: offline
I just re-read your post. You cannot do it with a G2 controller you need a radio that has the capability to do mixing in this case.
< Message edited by STLPilot -- 3/13/2004 6:44:58 PM >
Here At The Wall
(in reply to rajul)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU3
