RE: Assembly thread on Extreme flt edge    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Assembly thread on Extreme flt edge
Page: <<   < prev  2 3 4 5 6 7 8 9 [10] 11   next >   >>
Login
RE: Assembly thread on Extreme flt edge - 8/3/2004 8:07 AM
reaper329
Score: 100
Last Login: 7/13/2010
Status: offline
did anyone figer out how to cut down on the vibration using the saito .82 I start building tommaro any help would be great and pics thanks
_____________________________
Some people meditate I HOVER !!!!!!!!!!!
Hide Signatures
(in reply to Born2Fly)
       Post #: 226
RE: Assembly thread on Extreme flt edge - 8/5/2004 3:24 PM
redbirdy
Score: 100
Last Login: 1/3/2012
Status: offline
I just put one of these together myself. It is maybe the best made plane I've ever seen. The only thing I didn't particularly care for was the heat shrink for the clevises. I have my CG an inch back from the spar. This thing is awesome in knife edge flight and waterfalls.
Hide Signatures
(in reply to reaper329)
       Post #: 227
RE: Assembly thread on Extreme flt edge - 8/5/2004 3:31 PM
redbirdy
Score: 100
Status: offline
Much better than the goldberg eh. I was flying a goldberg extreme before this too. My EF came in at 10 oz lighter than the goldberg.
quote:
ORIGINAL: DFWS
Assembly Mods!!
I added GP Venus wheel pants for more of a scale look!!!
Steerable tail wheel from CG Extreme 330 profile ARF kit
all Dubro 4 - 40 hardware.
Changed the canopy color to black to look a little different
and match my CG Extreme 330 profile.
Hide Signatures
(in reply to DFWS)
       Post #: 228
RE: Assembly thread on Extreme flt edge - 8/10/2004 5:02 PM
ckoerner
Score: 100
Last Login: 3/2/2013
Status: offline
What is everyone coming out with weight with the Saito .72 on it? Mine came out at 4.7lbs. I was hoping it was going to be lighter. I can only see maybe getting rid of 2oz with a different receiver and battery pack.
Hide Signatures
(in reply to redbirdy)
       Post #: 229
RE: Assembly thread on Extreme flt edge - 8/10/2004 6:21 PM
JWilliams
Score: 100
Last Login: 2/6/2013
Status: offline
Craig, mine weighs in at about the same weight with a YS63 and I am totally pleased with its performance in all flight regimes. Your new carbon fiber gear will look great on it too, love mine. Jeff W.
Hide Signatures
(in reply to ckoerner)
       Post #: 230
RE: Assembly thread on Extreme flt edge - 8/10/2004 6:23 PM
ckoerner
Score: 100
Status: offline
Jeff,
It looks great with the gear.
Craig
Hide Signatures
(in reply to JWilliams)
       Post #: 231
RE: Assembly thread on Extreme flt edge - 8/11/2004 3:02 AM
Snyperx
Score: 100
Last Login: 6/20/2008
Status: offline
n/m
< Message edited by Snyperx -- 8/10/2004 6:26:46 PM >
Regards,
Snyperx
Hide Signatures
       Post #: 232
RE: Assembly thread on Extreme flt edge - 8/16/2004 4:54 PM
LVS
Score: 100
Last Login: 8/23/2010
Status: offline
Hi All,
I have a question. I took my newly assembled EF Edge 540 with Saito .72, all new radio and servos, Hitec Electron 6, Hitec 475HBs all around, and an HS85BB on the throttle. The Saito is new so I was going to run a tank through and fly. I believe the stock tank was leaking air because the stopper screw seems to have stripped so engine was running pretty rough. What I noticed was that the HS85BB was constantly moving the throttle(surging back and forth) with no change from the transmitter stick. I have read all about the HS81s not being up to snuff for this application considering the vibration, that is why I got the 85. Does it sound like the servo is bad or am I going to have to get a mini-digital?
Hide Signatures
(in reply to Snyperx)
       Post #: 233
RE: Assembly thread on Extreme flt edge - 8/16/2004 4:57 PM
wgeffon
Score: 100
Last Login: 10/27/2010
Status: offline
I dont think you'll need a digital servo to fix your problem..
If your throttle servo is bad replace it with a standard servo. You will have to open up the cutout where that servo goes but that istn as big deal.
Wayne
Hide Signatures
(in reply to LVS)
       Post #: 234
RE: Assembly thread on Extreme flt edge - 8/16/2004 5:04 PM
George E.
Score: 100
Last Login: 6/22/2011
Status: offline
Before you get the new servo...
Make sure the metal throttle pushrod is not rubbing against any metal surfaces.
Try a new servo extension if you are using one.
Hide Signatures
(in reply to wgeffon)
       Post #: 235
RE: Assembly thread on Extreme flt edge - 8/16/2004 5:22 PM
LVS
Score: 100
Status: offline
Thanks for the ideas. I never thought about the servo extension.
Wayne, I hate to put a standard size servo in because I am balancing at about 1/4" behind the spar. I was hoping to come out about an inch. Instead of the stock tail wheel, I used a Sullivan and a 1" Dubro wheel but I guess I probably should have used the stock setup as it places the actual wheel back further. I moved the engine as far back as the carb would allow. Battery is as far back in the wing as I can get it. Any other ideas for balancing without adding tail weight?
Hide Signatures
(in reply to George E.)
       Post #: 236
RE: Assembly thread on Extreme flt edge - 8/16/2004 5:36 PM
wgeffon
Score: 100
Status: offline
Yours is balanced pretty much were mine is..
I dont think the additional weight of a standard servo up front is going to make that big of a difference.
If it does, a tiny bit of tail weight will get you back to where you were.
Too many people IMO make the CG on these planes a bigger issue than it needs to be.
Wayne
Hide Signatures
(in reply to LVS)
       Post #: 237
RE: Assembly thread on Extreme flt edge - 8/16/2004 5:37 PM
ckoerner
Score: 100
Status: offline
I have a Saito 72 on mine also. I had to bite the bullet and add tail weight. It took about 1oz. This is my first 4 stroke. I couldn't believe the power with it on this plane. I have only about 10 flights on mine and the motor still is running very rich. Has unlimited verticle and does great climbing inverted flat spins. I would just add the weight and try it. The only other thing would be to move the battery to the outside of the fuse like some others have done.
Later,
Craig
Hide Signatures
(in reply to LVS)
       Post #: 238
RE: Assembly thread on Extreme flt edge - 8/16/2004 5:43 PM
tashley
Score: 100
Last Login: 12/5/2012
Status: offline
That's right, it' cg, smeegee.
Tomakazi
Hide Signatures
       Post #: 239
RE: Assembly thread on Extreme flt edge - 8/21/2004 6:07 AM
Snyperx
Score: 100
Status: offline
My edge construction is stalled at installing those darn aileron servo rods. I have Hitec 425's in the wing, but can not get the rods to line up with the control horns. What do I need to do to get these rods installed? I read the post by williams, but that's not working for me. my control horns are not very long. I hope I do not need to get new control horns becuase my LHS does not carry longer ones like the Dubro ones and I really want to get this brid in the air this weekend. I have been working on this for a week (only can work at it 15 min at a time with a new baby in the house). any help is appreciated.
< Message edited by Snyperx -- 8/20/2004 9:40:44 PM >
Regards,
Snyperx
Hide Signatures
(in reply to tashley)
       Post #: 240
RE: Assembly thread on Extreme flt edge - 8/21/2004 6:34 AM
TERMAGATOR
Score: 100
Last Login: 8/12/2006
Status: offline
hey guys...whats a CG?.......I bet it has something to do with "reynold's #"?
Hide Signatures
       Post #: 241
RE: Assembly thread on Extreme flt edge - 8/21/2004 5:59 PM
tashley
Score: 100
Status: offline
Snyperx, take a look at a construction thread I did on this plane in the User Product Review forum, post num. 23. I used Dubro heavy duty servo arms and Dubro ball links at each end and the push rods came out dead center of the slots. You have to use longer servo arms than stock to line em up.
< Message edited by tashley -- 8/21/2004 9:04:27 AM >
Tomakazi
Hide Signatures
       Post #: 242
RE: Assembly thread on Extreme flt edge - 8/21/2004 6:02 PM
tashley
Score: 100
Status: offline
Nah, the reynolds # is how many aluminum plates you use for reinforcement of the motor mount area.
Tomakazi
Hide Signatures
(in reply to TERMAGATOR)
       Post #: 243
RE: Assembly thread on Extreme flt edge - 10/21/2004 8:37 AM
N925WB
Score: 100
Last Login: 5/7/2013
Status: offline
Fellers,
What's the definitive choice for prop selection on the YS .63?
I'm getting ready for my maiden (hopefully this weekend), and I'd like to have an idea of what props to try out on the YS.
Thanks!
-Wayne
Hide Signatures
(in reply to DFWS)
       Post #: 244
RE: Assembly thread on Extreme flt edge - 10/21/2004 10:12 AM
STEVE LENZ
Score: 100
Last Login: 11/8/2004
Status: offline
I like the APC 14X4-W I am running 20% powermaster I may switch to some 30% cool power I have and give it a try. It can only get better.
Hide Signatures
(in reply to N925WB)
       Post #: 245
RE: Assembly thread on Extreme flt edge - 10/22/2004 12:08 AM
JWilliams
Score: 100
Status: offline
I have a YS63 on mine, I like the APC 13 X 4W fun fly prop. I tried the APC 14 X 4W and did not like it. The 14 X 4 had too slow of spool time for my taste but the YS will turn it. I run 30% coopers heli fuel. Jeff Williams
Extreme Flight RC, www.bandegraphix.com, team Airtronics
Hide Signatures
       Post #: 246
RE: Assembly thread on Extreme flt edge - 10/29/2004 3:02 AM
STEVE LENZ
Score: 100
Status: offline
Jeff I tried the 13X4W APC yesterday and I liked it more snap with the controls as well due to the extra speed it picked up turning 10700. The 14X4 W APC I had on was turning 9600 with 20% poewrmaster.
Hide Signatures
       Post #: 247
RE: Assembly thread on Extreme flt edge - 10/29/2004 3:49 AM
Born2Fly
Score: 100
Last Login: 3/13/2013
Status: offline
I have YS 63 w/ 13x5 prop on my Edge. I like it very much. It gives more airflow over the control surfaces.
Hide Signatures
(in reply to STEVE LENZ)
       Post #: 248
RE: Assembly thread on Extreme flt edge - 11/5/2004 5:47 AM
srxripper
Score: 100
Last Login: 3/11/2011
Status: offline
running a hs-55 on thr. no problems here-20flights. though i'm running a 46fx, not many vibs coming from this motor!
but i'm noticing alittle slop in my control surfaces! any suggestions? thanks
Hide Signatures
       Post #: 249
RE: Assembly thread on Extreme flt edge - 11/10/2004 5:22 AM
pequeajim
Score: 100
Last Login: 2/12/2013
Status: offline
Here's one that you won't see every day...
Powered by an AXI and TP 4s4p, and is a rocket with unlimited vertical.
It hovers well on a 4s3p too.
Jim!
Click to see fullsize image.
Click for fullsize
< Message edited by pequeajim -- 11/10/2004 5:25 AM >
Hide Signatures
(in reply to Burrito Bandito)
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
