RE: WOW!!! I just found a LOT of imperfections...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> RE: WOW!!! I just found a LOT of imperfections... Page: <<   < prev  1 [2]
Login
RE: WOW!!! I just found a LOT of imperfections... - 3/29/2004 5:52:06 AM
TrueScale
Status: offline
Jay,
Don't think you where quite ready for primer yet, let alone paint. Sorry. You may have a couple
things working against you here. 1. You might be sanding so much that the FG fuse is heating up
causing small bumps or the bumps are small on a tapering area that is very hard to see.
If heat is a problem causing the bumps get away from the epoxy/micro and jump to the fillers
that are much easier to sand and feather (should be like night and day) If it is the other I some
times add a little food coloring to the filler after each patch so you can easily see where your
at and the small dents are accented.
As david says forget the paint till you get it right. Also on the pin holes, turn off the light and stick
a flashlight inside the fuse and it should be obvious if there are pinholes or not.
Fun huh
Chuck
(in reply to davidfee)
       Post #: 26
RE: Sanding/Filler question - 3/29/2004 12:32:07 PM
soholingo
Status: offline
one thing, when wet sanding the primer a LOT came off very quickly. If I dry sanded it seemed to do better.
I should probably try that polyester compound ....
At any rate, I painted it. I will see if the balls show up during the sanding. I hope not....
(in reply to TrueScale)
       Post #: 27
RE: Sanding/Filler question - 5/30/2005 5:58:40 PM
soholingo
Status: offline
quote:
ORIGINAL: bomberboy
Jay,
If the bumps are small then I would quit sanding. Don't use epoxy/micro. go to
and auto paint store and get some "metal glaze" by Evercoat. It is very easy to
fill and sand and the neat thing is the more hardener you add the faster it cures.
Plus you can sand it to a feather edge. Kinda reminds you cake icing.
Its is a polyester but it will work great.
Chuck
Chuck,
I finally got around to getting some glazing. Its amazing how good this stuff is for filling those small pits. I bought a tube of 'bondo glazing' it doesn't require a hardner but the results are similar to what you are describing. Its beautiful thanks.
Jay
       Post #: 28
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU3
