Xperimental
Joined: 1/28/2004 From: balikpapankaltim, INDONESIA Status: offline
Hi boyd, You see, maybe you've noticed it before but i live in indonesia and it's pretty hard to get the components that i need specifically. Right now, i can get standard gws naro which a friend of mine uses for cyclic and t/r servos in his zoom. My question is, can i replace the cyclic servos (which normally uses hs-56b or hs-55) with standard gws naro servos? Hs-50 for t/r is the same servo that's used in hummingbird right? If it is, i can use the one on my hb/df for t/r servo on my zoom. I'm also trying to find a shop which sells hitec eclipse7 who will accept bank transfer (it's hard to find one that'll accept visa from indonesia). Or maybe you have a spare transmitter that you'd like to sell to me? Anyway i need one with 72mhz frequency. Thanks.
