OldScaleGuy
IN, USA Status: online
quote:
ORIGINAL: Thrushdust I've been working on the "system" for more than 10 yrs to get the proper effect! Yes there have been simpler and lighter versions that fit in smaller planes, but I'm always searching for the more realistic and longer lasting results even if the current 28lbs is about the limit I can haul around with my Saito 1.80. I worked on full-scale dusters for more than 12yrs and know the effect that I want to achieve to suit myself. But then again I'm also doing it for additional realism points in competition not just "wow factor" at the local field. There are 44 individually hand molded, trimmed, painted and weathered scale nozzles on my scale booms too that aren't necessary for your average ARF, but the static judges at Top Gun and Scalemasters tend to appreciate them so they're there. We'll be working an a "simpler" version for the RC Guys AgWagon, although that is quite a bit larger than your H9 Pawnee too. DH Dave, Do you have a drawing, sketch or pictures of your system that you could share with us. Thank you.
_____________________________
The difference between a good model and a great model is sandpaper. www.LeisureRcModels.com
