Thrushdust
Joined: 4/24/2002 From: Northeastern, NC, USA Status: offline
quote:
ORIGINAL: GPutt33 I see somebody's name and a certain Thrush in todays AMA mag I received. Just to correct the caption, page 19, in the Model Aviation, it's powered by a Saito 1.80 and the item on the right is the oil cooler. The static judges seemed to think the weathering and detailing is a bit improved from TG '03 when the previously posted photos were taken. Also, if you're wondering, the item on the left (under the right wing) is a wind driven air conditioner compressor. The wind driven spray pump can be seen spinning between the L/G struts on page 23. D. Hayes No, I don't have plans available for either size or version. Sorry!
