What other upgrades should I get?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> What other upgrades should I get?
Page: [1] 2 3 4   next >   >>
Login
What other upgrades should I get? - 3/19/2004 7:32:12 PM
viperspeed333
Status: offline
Hey. I Have a HPI RS4 SS with a fantom .15 engine, fantom tuned pipe, racing clutch, fiber brake disk, lightweight flywheel, fuel filter, high peformance air filter. I dont know what else there is to get for it. What would you all suggest? Thanks
       Post #: 1
RE: What other upgrades should I get? - 3/19/2004 7:45:37 PM
Boost-Dragon
Status: offline
better springs and better shock oil to transfer power to the ground and a little bit taller gearing to help maximize your SS's new found power. graphite shock towers for consistent suspension loading and a Rx battery pack for better servo performance. that's about it if you just bash. if you race(club .15 not legal) the graphite upper chassis and better main chassis and some ball diffs and better gearing. but if i were you just some new suspension components and that's it.
(in reply to viperspeed333)
       Post #: 2
RE: What other upgrades should I get? - 3/19/2004 8:22:45 PM
viperspeed333
Status: offline
awesome, thanks a lot for your help man....yea, i was thinking of getting some new shocks...any suggestions for new shocks and what weight of oil should i get? Thanks again for your help
(in reply to Boost-Dragon)
       Post #: 3
RE: What other upgrades should I get? - 3/19/2004 8:26:45 PM
newbie003
Status: offline
oh yeah viper remember when you said you placed your carb from the hpi ss motor to the fr.15 well i found a linkage set for slide carbs here it is
http://www2.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=A889&FVPROFIL=++&search3=Go
       Post #: 4
RE: What other upgrades should I get? - 3/19/2004 8:29:35 PM
viperspeed333
Status: offline
Hey, thanks for that...yea, i found it but my LHS didnt have it so i took a bunch of parts from Dubro and other companies and basically made the same thing. Ill post pics of it tonight to show you guys what it looks like now.
(in reply to newbie003)
       Post #: 5
RE: What other upgrades should I get? - 3/20/2004 3:00:21 AM
viperspeed333
Status: offline
but again, does anyone have any suggestions on good shocks to get for this car and what weight oil should i use in the shocks? thanks
       Post #: 6
RE: What other upgrades should I get? - 3/20/2004 4:19:38 AM
viperspeed333
Status: offline
Here are the pics with all the upgrades installed in the car...Thanks for everone who helped me with this
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 7
RE: What other upgrades should I get? - 3/20/2004 4:28:55 AM
rodrigo1508
Status: offline
I think that you would be fine with the hotbodies aluminum threaded ones. I have them and cant complain and you dont even have to build them. for the oil it depend of the track and how you drive,
       Post #: 8
RE: What other upgrades should I get? - 3/20/2004 4:38:34 AM
rodrigo1508
Status: offline
I dont know what servo you have but a good steering servo is good investment and in case you change car you can still use it. I dont know If you race and where but I found that foam tires gave me better handling also I liked more the light weight chassis on my rs4 3 than the stock.
Another thing is that I cutted the primer from the tank and sealed it , this ended the leaking.
(in reply to rodrigo1508)
       Post #: 9
RE: What other upgrades should I get? - 3/20/2004 5:18:40 AM
newbie003
Status: offline
rodrigo1508- where did you get the foam tires? and what kind of light chassis
       Post #: 10
RE: What other upgrades should I get? - 3/20/2004 5:42:11 AM
viperspeed333
Status: offline
I just bash and occasionaly do some drag races, so what would be the best type of oil for these conditions. And yea, the shocks form hot bodies look real good, so i probably will go with them. Thanks again for the help
< Message edited by viperspeed333 -- 3/20/2004 5:42:50 AM >
       Post #: 11
RE: What other upgrades should I get? - 3/20/2004 6:51:27 AM
rodrigo1508
Status: offline
I got my tires from my LHS. Some brands are Nitro Shoes, GQ, Ellegi,etc.
       Post #: 12
RE: What other upgrades should I get? - 3/20/2004 6:56:13 AM
rodrigo1508
Status: offline
I dont remember the brand I got it from and online store from UK and since then I have not bough from them so I dont even remember the site. but here is a pic
Click for fullsize
       Post #: 13
RE: What other upgrades should I get? - 3/20/2004 7:07:54 AM
joes75
Status: offline
quote:
ORIGINAL: viperspeed333
Spend the extra money and get the HPI threaded aluminum shocks, they are awesome. I noticed a big improvement in handling with them. Yes you have you have to build them but it was very easy to do..I used 40wt shock all around and I just bash. They look real nice also.
       Post #: 14
RE: What other upgrades should I get? - 3/20/2004 7:40:27 PM
viperspeed333
Status: offline
Nice, thanks...those were the ones i was originally looking for. Thanks again.
(in reply to joes75)
       Post #: 15
RE: What other upgrades should I get? - 3/22/2004 7:21:51 PM
viperspeed333
Status: offline
Can anyone tell me whether the Woven Graphite Upper Deck set actually helps the car with handling and stiffening the ride, like Hpi says it does? thanks
       Post #: 16
