RE: Ann is building the burito
Tower Hobbies
Logged in as Guest
  Printable Version
50 Size 3D Profile - RTF
Seller:  DAVIS300
Details:   $275.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Ann is building the burito
Page: <<   < prev  10 11 12 13 14 [15] 16 17 18 19   next >   >>
Login
RE: Ann is building the burito - 3/30/2004 5:08:17 AM
BasinBum
Status: offline
Ann,
Great job on your first build, the short time and excellent job should inspire many here to do the same. After reading through the thread I have noticed a few things.
I think you have done a lot to repair European/ American relations here on RCU.
A lot of your husbands friends have been stopping over while he is gone.......
I will never feel the same "gratification" building a plane as I used to (unless my wife really, really likes it).
How come Swany never posted a picture in his skivies building a Sledge?
(in reply to Wowbagger)
       Post #: 351
RE: Ann is building the burito - 3/30/2004 5:46:31 AM
John Murdoch
Status: offline
Ann, when the hell are you going to fly the thing? All I ever see is "Ann is building the Burito". When in the world is the building going to end and the flying begin?
(in reply to BasinBum)
       Post #: 352
RE: Ann is building the burito - 3/30/2004 8:07:35 AM
PROSIS1
Status: offline
good morning fellows, Wake up ! the sun is shining !!!
to answer all your questions
sweet termagator : no they are no tri stock, the stab is glued with epoxy on the CF spar and top fuse. did I forgot something?
constrictor: the spar is painted and the picture of the painting process is somewhere on this thread. I painted it before instaling it
232cap tain : I will fly it as soon my hubbie is back
this morning I will take care of myself, the sun is shining and I will go outside for some oxygen !
(in reply to John Murdoch)
       Post #: 353
RE: Ann is building the burito - 3/30/2004 10:24:08 AM
PROSIS1
Status: offline
I contacted a good fellow with my problem of radio setup. he says he will come tomorrow evening, but he says that he need some info
he needs the suggested flight controls throw in low and high rate (I duno what it is, I just translate)
he said also he need the suggested position of the CG for battery pack positioning (I don't understand why he need the cg position to secure the battery pack)
this mean I will have to finish the plane for tomorrow !!!
(in reply to PROSIS1)
       Post #: 354
RE: Ann is building the burito - 3/30/2004 10:32:59 AM
Spacey
Status: offline
Ann all the info he needs should be on the plans and in the instruction manual. Especially the cg will be indicated on there. Throws will probably be a bit of salmonbug's choice, but i'm sure paul would have given an indication somewhere in the manual. We always use the battery because it is one of the heavier single components in the plane to move the cg around.
       Post #: 355
RE: Ann is building the burito - 3/30/2004 1:10:49 PM
matchlessaero
Status: offline
Ann, congratulations on a wonderful job of building that Burrito. Your covering job shows that you realy do know what you are doing with a covering iron.
When you are done with the plane, we need a picture of you holding the plane outside. When you take this picture, you need to hold the plane with the bottom side facing the camera, and the nose pointing up, and you should be looking with a blank stare over the the camera person's right shoulder. If you go to the ProBro website gallery, you will see what I mean. This pic is the original requirement for being in the Profile Brotherhood.....
_____________________________
Go fast turn left-----3D is life-----Fly S.M.A.L.L. I'm having an RC identity crisis!!!!!!!!!
(in reply to Spacey)
       Post #: 356
RE: Ann is building the burito - 3/30/2004 1:25:07 PM
PaulSwany
Status: offline
quote:
ORIGINAL: BasinBum
LMAO!! I decided it would be best to leave those kind of shots for Gator... He said he was going to do a rudder pose.....
       Post #: 357
RE: Ann is building the burito - 3/30/2004 1:26:56 PM
PaulSwany
Status: offline
Ann - For throws... Just set the low rate for about 1" travel for the aileron's and elevator, 2" for the rudder. For high rates, set all you can get and dial back from there depending on flying styles and preference.....
Very nice work... I'm soooo proud of you... I'm sure you're husband will be completly blown away!!!
(in reply to PaulSwany)
       Post #: 358
RE: Ann is building the burito - 3/30/2004 1:35:38 PM
Quicker
Status: offline
I started covering mine last night. Ann, I wish you were here to cover mine. I am not nearly as talented as you are in the covering area. I was cussing up a storm last night....
Seems like everybody has a Burrito now. I don't know how Swany keeps up with the orders!
       Post #: 359
RE: Ann is building the burito - 3/30/2004 1:47:53 PM
PaulSwany
Status: offline
I do have a few more gray hairs... But a really big smile on my face for sure!!
(in reply to Quicker)
       Post #: 360
RE: Ann is building the burito - 3/30/2004 2:05:09 PM
Quicker
Status: offline
I can only imagine....must be a proud pappa
       Post #: 361
RE: Ann is building the burito - 3/30/2004 2:10:03 PM
sky_pilot_12
Status: offline
Ann did you use any heat gun to begin covering. i have just ordered a Tower Hobbies Covering iron and i wanted to know if i will need a heat gun. I really am intrested in covering and building. I admire you and hope to build as fast and good as you do. Great plane.
Sky
Sky Pilot
       Post #: 362
RE: Ann is building the burito - 3/30/2004 3:10:06 PM
PROSIS1
Status: offline
To answer everybody
-yes I will take that pic as soon the plane is finish
-no you don't need a heat gun. I have one, but didn't use it on the burrito . you can easy apply multi layers color scheme by either start to work at low temp and the increase gradualy or use the windex trick
(in reply to sky_pilot_12)
       Post #: 363
RE: Ann is building the burito - 3/30/2004 5:20:57 PM
A. Holden
Status: offline
I started covering mine last night as well and was also cussing- It has all been pretty easy until now- I was so pissed that I was about to end up with a pile of toothpicks! I finally gave up on it for the night after I stripped several of the pieces more than 2x each- so far I hate covering........... the least fun part of building in my opinion-
Alex Holden
Pro Bro #555
alex2@aholdendesigns.com
       Post #: 364
RE: Ann is building the burito - 3/30/2004 5:32:44 PM
PROSIS1
Status: offline
quote:
ORIGINAL: A. Holden
Alex Holden
Pro Bro #555
NO! it's fun, but this required some training. Once you will get the trick you will be better than termagator !
(in reply to A. Holden)
       Post #: 365
RE: Ann is building the burito - 3/30/2004 5:35:00 PM
A. Holden
Status: offline
that is wishful thinking.............
       Post #: 366
