Burrito Bandito
Joined: 5/1/2002 From: Collierville, TN, USA Status: offline
Ann, That plane absolutely ROCKS! Great job. I also think that you should be O.K. with the fuel lines where they are. However, when Paul posts his pics, you may decide to alter your setup a bit. Sometimes the engine will start in reverse if flip starting and the lines could get sucked into the prop if too close. You may have posted the information already, but please let us know the total weight when everything is installed. If my daughter see's this one, she will want mine covered like that. She sends hugs back to your children. When I showed her your post, she asked if they would like to come over to play It took a few minutes to explain the issue of distance....haha. She did come up with a solution though....she said you could all come here on your vacation!!! Congratulations on the build John
_____________________________
John
