RE: Ann is building the burito    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Twist 3D 40 (less Rx) - RTF
Seller:  stuk_at_work
Details:   $250.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Ann is building the burito
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Ann is building the burito - 3/22/2004 3:26 PM
PROSIS1
Score: 100
Last Login: 8/2/2004
Status: offline
I have a problem here
instructions call about gluing a piece of carbon fiber to join the trailing edges, this is not in the box and I can't find that in the workshop. should I go to buy or may I replace with what I found.
I found this, and i think salmonbug call that fiberglass, is that the same?
Click to see fullsize image.
Click for fullsize
< Message edited by wife cleaning balsa dust -- 3/22/2004 7:28:18 AM >
Hide Signatures
(in reply to PROSIS1)
       Post #: 51
RE: Ann is building the burito - 3/22/2004 4:45 PM
blue ice
Score: 100
Last Login: 6/30/2009
Status: offline
I have not built this kit but that is probably for putting in the middle of the wing after it is assembled. You ca the cloth on for strengh. The carbon fiber should be some black looking stuff like what you have in the middle of the fuse.
Hide Signatures
       Post #: 52
RE: Ann is building the burito - 3/22/2004 4:58 PM
Quicker
Score: 100
Last Login: 3/15/2006
Status: offline
The carbon fiber strip is a black strip (looks like black cloth) about 1/4 inch wide and about 25 to 30 inches long. You need to cut 2 10 inch long pieces out and glue that over the joint of the 2 23 inch long spars. A 1/4 wide by 1/8 thick by 10 inch long hardwood piece is glued on top of that.
I did mine by taking the CF strip and laying on top of the joint. I then put the hardwood on top of that and clamped it together (MAKE SURE IT'S PERFECTLY STRAIGHT!). I then took my extra thin CA and wicked it in to glue the assembly together. Just take the thin CA and let it run into the cracks of the joints. I think you should really use CA glue for this part!
< Message edited by Quicker -- 3/22/2004 7:59:20 AM >
Hide Signatures
(in reply to blue ice)
       Post #: 53
RE: Ann is building the burito - 3/22/2004 5:17 PM
PROSIS1
Score: 100
Status: offline
is that black strip in the box?
Hide Signatures
(in reply to Quicker)
       Post #: 54
RE: Ann is building the burito - 3/22/2004 5:19 PM
Quicker
Score: 100
Status: offline
Yes. Mine was folded up with the wood. Look around the shop. It might have fallen on the floor....the kids might have grabed it thinking it was a ribbon, it might be under something.
Hide Signatures
       Post #: 55
RE: Ann is building the burito - 3/22/2004 5:26 PM
PROSIS1
Score: 100
Status: offline
ok
Hide Signatures
       Post #: 56
RE: Ann is building the burito - 3/22/2004 5:44 PM
PROSIS1
Score: 100
Status: offline
i empty the workshop garbage container! , I searched à lot everiwhere, I couldn't find it.
I fully understood what to do, may I substitute with the white stuff I showed above?
Hide Signatures
       Post #: 57
RE: Ann is building the burito - 3/22/2004 5:52 PM
Quicker
Score: 100
Status: offline
No....that is completely different stuff. I think we need some more help here. Try sending a PM to Swany and ask his advice. Since you said your husband had extra 1/4 square hard stock, you might be able to substitute that instead of the thin hardwood and CF strip. It would require cutting the spar notches out a little on the inner ribs, though.
If you can wait, maybe he can mail you a new CF strip.
Hide Signatures
       Post #: 58
RE: Ann is building the burito - 3/22/2004 5:55 PM
PROSIS1
Score: 100
Status: offline
I can't wait, The bird must be finish in 3 weeks I will go by gluing spruce sticks and enlarge the notches (I understood what you mean)
this should work fine don't u think so ?
Hide Signatures
       Post #: 59
RE: Ann is building the burito - 3/22/2004 5:58 PM
Quicker
Score: 100
Status: offline
I think you'll be fine. It looks to me like Swany was trying to save weight by using the CF strips and thinner hardwood. It's gonna add a few ounces, but the 46 will be able to handle it.
Cover it and your hubby will never know
< Message edited by Quicker -- 3/22/2004 8:58:34 AM >
Hide Signatures
       Post #: 60
RE: Ann is building the burito - 3/22/2004 6:10 PM
PROSIS1
Score: 100
Status: offline
I think he will be able to see it when he will open the radio access hatches
I will explai this is my personal female touch to improve the design !!
before I go I will post a pics of everithing before gluing.
I have a other concern, there is something I don't understand on the plan.
on the main spars (the one I am going to reinforce) there is a shadded aera in the center.
I first tough this shaded aera was showing the position of the reinforcement strip, but it's much more longer than 10 inches
what is it?
Hide Signatures
       Post #: 61
RE: Ann is building the burito - 3/22/2004 6:15 PM
Quicker
Score: 100
Status: offline
Well, I'm at work right now, so I can't look at the plans, and I don't remember. I'm here for another 7 hours
Somebody else?
Hide Signatures
       Post #: 62
RE: Ann is building the burito - 3/22/2004 6:22 PM
PROSIS1
Score: 100
Status: offline
Ok I am ready to go
here is a pic showing two 10 inches long 1/4 spars made in the strongest wood I could find (I think it's from a tree called 'pin" in french)
I plan to glue them in the center of each 1/4 balsa spars assembly with epoxy
I also draw arrows on the ribs showing the notches I plan to enlarge to 1/2 inch total depth
GO ?
you need to have a close look on the pics to see my arrows
Click for fullsize
< Message edited by wife cleaning balsa dust -- 3/22/2004 10:23:17 AM >
Hide Signatures
       Post #: 63
RE: Ann is building the burito - 3/22/2004 6:28 PM
Quicker
Score: 100
Status: offline
Looks good.
You sure you haven't built a plane before?
Hide Signatures
       Post #: 64
RE: Ann is building the burito - 3/22/2004 6:31 PM
PROSIS1
Score: 100
Status: offline
no, never, but I live in airplanes and building project since 7 years......
Salmonbug is crazy !!!
let's go !
Hide Signatures
       Post #: 65
RE: Ann is building the burito - 3/22/2004 7:29 PM
PROSIS1
Score: 100
Status: offline
i align all the ribs on the spare. the main spar is exactly at the position showed on the plan, but the trailing ege spar is aproximatly 1/4 inches backward of the position showed on the plans, do I have to cut the ribs to correct ?
Hide Signatures
       Post #: 66
RE: Ann is building the burito - 3/22/2004 7:30 PM
Quicker
Score: 100
Status: offline
NO! Swany said this was a misprint on the plans. Just leave the ribs as they are and glue on the trailing edge.
Hide Signatures
       Post #: 67
RE: Ann is building the burito - 3/22/2004 7:34 PM
PROSIS1
Score: 100
Status: offline
ok, thanks a lot !, I think I am ready to start to glue. I corrected a minor mistake. on the pics where I show the ribs I plan to enlarge the slots (the ribs with arrow) one of the ribs is not the correct one because it doesn't have the notches for servo rails. I cuted in the good rib
Hide Signatures
       Post #: 68
RE: Ann is building the burito - 3/22/2004 7:40 PM
Quicker
Score: 100
Status: offline
Good thing you caught that....I didn't notice.
Hide Signatures
       Post #: 69
RE: Ann is building the burito - 3/22/2004 8:41 PM
PROSIS1
Score: 100
Status: offline
I have a problem here. I am looking ahead and discover that I have to glue stuffs called "shearwebs", the problem is that on my burito, the main spars edges aren't parallel with each other, so ther will not be a good contact, If i fill the gaps with glue this will be heavy and there is a risk maybe to go over the maximal structural take off weight, or maybe be unable to rotate the plane !
Hide Signatures
       Post #: 70
RE: Ann is building the burito - 3/22/2004 9:40 PM
Quicker
Score: 100
Status: offline
How far out of parallel are they? Mine were a little out of square, but not too bad. I clamped the sheer webs to the spars and they formed a nice fit. I wicked in a bit of thin CA and they held nicely.
Can you get a close up picture with a sheer web pinned in so we can see?
Hide Signatures
       Post #: 71
RE: Ann is building the burito - 3/22/2004 9:44 PM
PROSIS1
Score: 100
Status: offline
I am not at placing the sehar webs yet, I was expecting.........
in fact if you look at the notches made for the spars in the ribs, you can see that the spars edges wont be paralel once fit
Hide Signatures
       Post #: 72
RE: Ann is building the burito - 3/22/2004 9:47 PM
Quicker
Score: 100
Status: offline
Yep. The balsa that is used is flexible enough that it wasn't an issue.
Hide Signatures
       Post #: 73
RE: Ann is building the burito - 3/22/2004 10:22 PM
PROSIS1
Score: 100
Status: offline
because of my lack of building skills, I made a modification to the building sequence.
normaly, you glue the trailing edge to the ribs and then sand them to obtain the correct curvature. at my first atempt to sand, my sanding tool hited a rib and unglued it from the trailing edge. this is very fragile. to make it stronger, I lifted the back of the wing a bit, squeezed both upper trailing sheetings (wing is upside down on the board, so they are the upper ones), weighted the assembly and glued it in place on the ribs and the trailing edge with thin CA) in fact there was no sanding required on that side in my opinion so I have been able to glue it imediatly
this make the aera to sans more strong and rigid
hope I didn't made a mistake
Hide Signatures
       Post #: 74
RE: Ann is building the burito - 3/22/2004 10:25 PM
Quicker
Score: 100
Status: offline
I'd like to see a pic of that. I used a nice new sharp blade to cut it to the proper angle, then sanded it smooth.
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
