RE: Taco .25 plans
Tower Hobbies
Logged in as Guest
  Printable Version
Ohio Model Products Fusion X3D - 90
Seller:  cdp2buck
Details:   $525.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Taco .25 plans
Page: <<   < prev  12 13 14 15 16 17 18 19 20 [21]
Login
RE: Taco .25 plans - 3/25/2008 7:51:05 PM
PaulSwany
Status: offline
quote:
ORIGINAL: flyinrog
A friend built a taco for me, I have an OS .25LA in it,,havent mounted the servos yet, he built it for me months ago and its on top of my fridge right now..havent flown anything but elect yet this year...and I sponser 2 1/2A flyins a year,I have a .,25FX but never have run it...I have been reading these threads for hours!!!..Paul do you still have this same plane..I dont know if mine is a ff or an original, its covered and rtf except for radio gear....and tank.......very good reading...Rog
I have the original taco hanging from the rafters in my shop.... Haven't flown it in a while... but it's still alive!
_____________________________
SwanysHouse
Home of the Taco, Burrito and Mojo BayBee!
(in reply to flyinrog)
       Post #: 501
RE: Taco .25 plans - 3/25/2008 8:17:40 PM
flyinrog
Status: offline
Thanks for the replies paul, I was really concerned about the glide, I have an Uproar and it doesnt glide far at all!!, you run out of gas and its all you can do to get to the landing strip,,,cant wait to get this thing in the air....Rog
Ever walk into a room and forget what you went in for?...ADHD, welcome to my world,it happens everyday!
(in reply to PaulSwany)
       Post #: 502
RE: Taco .25 plans - 3/26/2008 7:25:32 PM
flyinrog
Status: offline
Oh and what size battery do you put in this thing?...Rog
       Post #: 503
RE: Taco .25 plans - 3/26/2008 7:33:30 PM
somegeek
Status: offline
I'm using a 4.8V 700mAh Nimh Hydrimax pack myself FWIW. 1.95oz
somegeek
Fly safe, have fun. Measure three times, cut once. The man who makes no mistakes does not usually make anything.
       Post #: 504
RE: Taco .25 plans - 3/26/2008 8:24:03 PM
PaulSwany
Status: offline
I've used a 6 volt NiMh 700 mAh from batteryspace.com. They hold up pretty good. You could also go with a small lipo.
SwanysHouse
(in reply to somegeek)
       Post #: 505
RE: Taco .25 plans - 3/27/2008 5:51:31 AM
somegeek
Status: offline
Ready for the maiden flight...
A lot heavier than I wanted... 2lb 11 oz... tried to save weight here and there. Imagine a lighter engine woulda made a difference. This GMS .32 is 12.65oz. Hoping a 10x3 will pull it around okay.
The carbon fiber ribbon I put on the spruce member down the middle of my fuse just didn't cut it so I added a piece of Carbon Fiber Strip bolted in place with 2-56 hardware. Very rigid tail now.
Now I just need a good day at the field.
somegeek
       Post #: 506
RE: Taco .25 plans - 3/27/2008 3:45:08 PM
PaulSwany
Status: offline
Looks nice! good luck with the maiden...
In the Fat Free Taco design, I use a fiberglass rod down the fuse to help with stiffness… Also makes it a lot stronger and lighter…
SwanysHouse
       Post #: 507
RE: Taco .25 plans - 3/27/2008 4:12:46 PM
somegeek
Status: offline
quote:
ORIGINAL: PaulSwany
Thanks, Paul.
I saw that in your FF thread(partially answered my question regarding how you got it lighter!).
Regarding the materials, what is the difference between fiberglass and CF rods of the same dimensions? Was the tube of this size not rigid enough?
somegeek
       Post #: 508
RE: Taco .25 plans - 3/28/2008 9:13:53 PM
balsabuster2003
Status: offline
"Now I just need a good day at the field." (from SomeGeek)
I understand we'll have good weather July 15th!!
non impediti ratione cogitationis
       Post #: 509
RE: Taco .25 plans - 3/28/2008 9:20:39 PM
somegeek
Status: offline
Sweet - nice to plan ahead.
somegeek
(in reply to balsabuster2003)
       Post #: 510
RE: Taco .25 plans - 6/6/2008 9:51:11 AM
indy
Status: offline
quote:
ORIGINAL: PaulSwany
I never make a list up... but basically you'll need
3-4 sticks 1/4 sq
2 sticks 1/4 x 3/8
2 sticks 1/8 x 1/4
3 - 4 sheets 1/16 x 3 sheeting
1 - 2 sheets 1/16 x 3 ribs
8" x 3/8 x 1/2 maple
some 1/4" scrap
Hi Paul,
I've just started with my Taco, but one thing I did not catch: what to use for leading edge ?
Tnx
Indy
       Post #: 511
Jump to:
