Wonder Speed ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> Wonder Speed ?
Page: [1]
Login
Wonder Speed ? - 6/17/2002 8:17:18 PM
fotta
Status: offline
Does anyone know how fast a typical Sig Wonder with a .15 (specifically a .15LA with an 8x4 prop) will fly ?
       Post #: 1
Wonder Speed ? - 6/17/2002 9:02:49 PM
KevinSheen
Status: offline
I don't have access to a radar gun but mine is pretty fast with a .15 FP and an 8x4 prop weighing in at 29 oz.
The real problem is the plane is fairly small so you'll want to keep it close. Mine actually flies pretty smooth going flat out.
Kevin
(in reply to fotta)
       Post #: 2
Wonder Speed ? - 6/17/2002 9:18:05 PM
fotta
Status: offline
Yeah, mine is pretty fast and smooth too. However it is quite a bit heavier than yours - it weighs 35.5 ounces with 3 standard S3004 servos and a 600 mAh battery pack. I am guessing that you are using smaller components, no?
Does anyone know how fast these things fly?
(in reply to fotta)
       Post #: 3
Wonder Speed ? - 6/17/2002 9:53:20 PM
KevinSheen
Status: offline
Ya, I went with 2 mini and 1 micro (on the throttle) servos. I also used a 270 Nicd pack.
(in reply to fotta)
       Post #: 4
Wonder Speed ? - 6/17/2002 10:00:01 PM
JohnVH
Status: offline
Im thinking about a webra speed .28 for mine, got a magnum 15 on it now and its not too bad
(in reply to fotta)
       Post #: 5
Wonder Speed ? - 6/17/2002 10:12:14 PM
fotta
Status: offline
A speed .28? I'd love to hear how that works out.
(in reply to fotta)
       Post #: 6
Wonder Speed ? - 6/18/2002 1:25:38 AM
JohnVH
Status: offline
Me too! I had to add some nose weight to it anyway, might as well put a bigger mill on it! Should be fast then huh?
(in reply to fotta)
       Post #: 7
Wonder Speed ? - 6/19/2002 8:06:17 AM
WolverineRC
Status: offline
With that .28 you should be able to cut a little weight by leaving the wing off
(in reply to fotta)
       Post #: 8
Wonder Speed ? - 6/19/2002 10:01:41 AM
JohnVH
Status: offline
new meaning for lawn dart? Maybe if I only take a foot off each side
(in reply to fotta)
       Post #: 9
Wonder Speed - 6/19/2002 5:38:06 PM
hooleyMnM
Status: offline
Try the 15 LA with a 7x6 prop. Makes a lot of difference over the 8x4.
(in reply to fotta)
       Post #: 10
Building one now - 6/24/2002 10:44:10 PM
johnhardy1
Status: offline
OK first what is everyones "best guess " of how fast their Wonder flies flat out ? 60 MPH ? More ?
Im putting in a MDS .18 but I only have one servo right now, a Expert SL300 which will probably go on elevator. What servos do you all recommend for ailerons ? I was thinking a HS-225MG ?
Would I do better to put some kind of mini servos for ele & ail ?
Guess I'll go with a HS-55 for throttle.
What are your suggestions ?
John
(in reply to fotta)
       Post #: 11
Wonder Speed ? - 6/25/2002 12:14:36 AM
fotta
Status: offline
Yeah, I'd guess that mine is around 50-60 mph,... or so,... It's hard to judge.
I'm using S3004 and no problems so far
(in reply to fotta)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
