RE: Balsa USA enforcer    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Balsa USA enforcer
Page: <<   < prev  14 15 16 17 18 19 20 21 22 [23]
Login
RE: Balsa USA enforcer - 12/29/2012 2:59 AM
FLIGHTJOCKEY
Score: 100
Last Login: 5/9/2013
Status: offline
to set the thrusrt angle on the fan pod i gave it about 3 degrees up thrust just as I would do on an pusher it seemed to work well botht he enforcers are electric now i make and sell the pods to fit a 5 " dynamax of ramtec fan units ther are fiberglass with wood inner frame
Hide Signatures
(in reply to combatpigg)
       Post #: 551
RE: Balsa USA enforcer - 12/29/2012 4:25 AM
combatpigg
Score: 376
Last Login: 5/20/2013
Status: online
I see. Thanks for the explanation.
If you had to make an adjustment to the thrust angle after flight testing..is it adjustable..?
_____________________________
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to FLIGHTJOCKEY)
       Post #: 552
RE: Balsa USA enforcer - 12/29/2012 4:56 AM
FLIGHTJOCKEY
Score: 100
Status: offline
you could put shims uner the front or rear, however i have put alot of time into these pods the original pod was made from jet joe and the plans are in rc modeler magizine for the 6" byron fan you have to build that one from srcatch, I re engeerned the unit for 5 ' fans the angel I have put in to the are perfect I made a fiberglass mould and have the inetior wood parts lazer cut
Hide Signatures
       Post #: 553
RE: Balsa USA enforcer - 12/29/2012 6:10 AM
combatpigg
Score: 376
Status: online
There is a guy in the 1/2A forum who is piecing together a little fan unit for a .09 engine. He's doing a great job, but it looks more challenging and exacting than building a "ship in a bottle".
My guess is that you need to find the thrust angle that agrees with the planes' natural glide trim with no power.
Hide Signatures
       Post #: 554
RE: Balsa USA enforcer - 12/29/2012 6:48 AM
FLIGHTJOCKEY
Score: 100
Status: offline
the pods i use with the 5" fans are perfect no need to mess with the angle, i have spent countless hrs getting it right, many people who try to do build thing with no idea what there doing useally ends up in a crashed airplane
and also balancing the plane correct makes a a big difference its always better to be nose heavy than tail heavy
Hide Signatures
       Post #: 555
RE: Balsa USA enforcer - 12/29/2012 2:28 PM
nickeast
Score: 100
Last Login: 5/19/2013
Status: offline
Well in my experience, Too Nose Heavy flies poorly.... Too Tail Heavy Flies Once... So I can only agree that the CG is a very critical measurement.
FLIGHTJOCKEY
Do you have pictures of your setup and could you give a brief rundown of the reasons that you chose what you did? Please include batterys, ESC, ...
Nick
Hide Signatures
       Post #: 556
RE: Balsa USA enforcer - 12/29/2012 2:39 PM
oneaew@msn.com
Score: 122
Status: offline
nick i dont know how to send pictures on here if you want to send me your email i can send you some that way allen
Hide Signatures
(in reply to nickeast)
       Post #: 557
RE: Balsa USA enforcer - 12/29/2012 3:03 PM
FLIGHTJOCKEY
Score: 100
Status: offline
i Use 4035-640 high output outrunners for motors, castle 100 hv esc in 10 cells of lypo on one of the planes. the other has fly, fly 110 hv esc, hyperion 4035-64 motor on 10 cells of lypo ill take some photos this wekend sometime and attach as far as cg settings you arte correct most cg settings go from 20 to 30 plus % when i build anything new i start where the kit says to balance if is scratch or a modified kit ill strt at 25 % when i fly it ill get it up and flying trim it out and see from there, a dive test tell what you really need to know, now days with the internet there are so many CG caculator programs out thet that work spot on nothing like the old, (35 years ago we really need to know out stuff. I guess after 30 years in the Air Force I picked up a few pointers about aero dynamics
Hide Signatures
(in reply to oneaew@msn.com)
       Post #: 558
RE: Balsa USA enforcer - 12/29/2012 7:10 PM
nickeast
Score: 100
Status: offline
FLIGHTJOCKEY,
Pictures are appreciated.....
neaew@msn.com">oneaew@msn.com.... my email is nickeast@aol.com any help is appreciated
Nick
Hide Signatures
       Post #: 559
RE: Balsa USA enforcer - 12/30/2012 6:25 AM
nickeast
Score: 100
Status: offline
Quick Question.... seems that some of the planes are heavy ... is it possible to build one at 6lbs, if using a .60 size engine ? What is a good engine/prop pair for this plane in the .6o size?
Nick
Hide Signatures
       Post #: 560
RE: Balsa USA enforcer - 12/30/2012 7:40 AM
FLIGHTJOCKEY
Score: 100
Status: offline
I have done many prop static tests on many different motors, i use only apc 11x7 onn .60/.61 engine, getting about 8 lbs of static thrust the average encorcer will be 8 to 10 lbs depending whrt you do to it even if you had a 12 lb plane 8 lbs of thrust will still make a fast plane
Hide Signatures
       Post #: 561
RE: Balsa USA enforcer - 1/1/2013 10:16 PM
nickeast
Score: 100
Status: offline
ound another Balsa USA ENFORCER build over here....
http://www.rcgroups.com/forums/showthread.php?t=1152315&highlight=enforc
Nick
Hide Signatures
       Post #: 562
RE: Balsa USA enforcer - 1/1/2013 10:49 PM
FLIGHTJOCKEY
Score: 100
Status: offline
Nick there tons of photos all over RCU on Balsa usa eforcers lok at this thread from the beginning
http://www.rcuniverse.com/forum/m_1663087/mpage_22/key_/tm.htm
Hide Signatures
       Post #: 563
RE: Balsa USA enforcer - 1/27/2013 1:52 AM
FLIGHTJOCKEY
Score: 100
Status: offline
My new modified enforcer, has twin magnum .45, retracte and doors, made the cockpit and vaccumed formed a canopy
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 564
RE: Balsa USA enforcer - 1/27/2013 1:56 AM
FLIGHTJOCKEY
Score: 100
Status: offline
more photos
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 565
RE: Balsa USA enforcer - 1/28/2013 6:53 PM
wyo69cowboy
Score: 105
Last Login: 5/17/2013
Status: offline
Wow, nice work! Not much left of the original Enforcer Do those engines have crankcases that can rotate? Can't figure out how you got the mufflers to both face the inside...
Crashing my way to being a better pilot!
Saito Club# 679
Hide Signatures
       Post #: 566
RE: Balsa USA enforcer - 1/28/2013 7:06 PM
FLIGHTJOCKEY
Score: 100
Status: offline
the motor's are the old style of magnums, where thr both the front and rear hubs come off, on the right motor I switched the front and rear to get the exhaust on the left I also took the carb apart, and flipped it so the bottom is on the top, I did this so the throttle rod to the servo is on the opposite of exhaust total weight dry is 13.0 lbs i am getting 14.8 lbs of ststic thrust, should fly very well and fast
Hide Signatures
(in reply to wyo69cowboy)
       Post #: 567
RE: Balsa USA enforcer - 2/2/2013 1:53 AM
Strykaas
Score: 123
Last Login: 5/18/2013
Status: offline
Very nice work dude !
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
Hide Signatures
       Post #: 568
RE: Balsa USA enforcer - 3/12/2013 12:34 PM
nickeast
Score: 100
Status: offline
FlightJockey,
WOW .... have you flown it? Keep us up to date!!!!
Nick
Hide Signatures
(in reply to Strykaas)
       Post #: 569
RE: Balsa USA enforcer - 3/12/2013 8:11 PM
FLIGHTJOCKEY
Score: 100
Status: offline
flys great stands on its tail real well flys well over 125 mph has 15.5 lbs of static thrust and its weitgt is 12.4 lbs
stay tuned for another build it will be 30% larger nose and tail area larger , with twin .75 pushers set up just like the stock enforcer morter set up but totally altered wing and cockpit with retracts
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by FLIGHTJOCKEY -- 4/9/2013 3:04 AM >
Hide Signatures
       Post #: 570
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.515RCU1
