RE: Balsa USA enforcer    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Balsa USA enforcer
Page: <<   < prev  14 15 16 17 18 19 20 [21] 22 23   next >   >>
Login
RE: Balsa USA enforcer - 5/23/2010 11:03 PM
oneaew@msn.com
Score: 122
Last Login: 5/20/2013
Status: offline
are you talking about the enforcer i just put a nose spinner on like u do and stick my hand in side it to start it allen
Hide Signatures
(in reply to fullmoon_sg)
       Post #: 501
RE: Balsa USA enforcer - 5/23/2010 11:08 PM
oneaew@msn.com
Score: 122
Status: offline
i had a servo for each aileron and 2 for the elv. mineflys just great allen
Hide Signatures
       Post #: 502
RE: Balsa USA enforcer - 5/23/2010 11:11 PM
2000redrocket
Score: 110
Last Login: 11/12/2012
Status: offline
we also did seperat servo under the wing for everything. we should of put larger fuel line in the tank to the engine but the seperat servos work better than the cables i think.
Hide Signatures
(in reply to oneaew@msn.com)
       Post #: 503
RE: Balsa USA enforcer - 5/24/2010 1:35 AM
gassprint1
Score: 100
Last Login: 7/1/2012
Status: offline
HOW DID YOU HOOK UP 2 FOR THE ELEVATOR AND WHY WOULD THE LARGER FUEL LINE BE NEEDED. I'M STILL WORKING ON THE WINGS. I HATE THE SANDING PART. HAVEN'T CUT THE SLOT FOR THE HINDGES YET. THE FUSE IS SITTING FROM WHEN IF FIXED IT FROM BEING OUT OF WACK AND HAVE THE SHEETING ON IT. STILL HAVE TO FIX THE EDGES WHERE IT MEETS THE SIDES. I WORK ON THE WING EVERY NOW AND THEN......
Hide Signatures
(in reply to 2000redrocket)
       Post #: 504
RE: Balsa USA enforcer - 5/24/2010 3:28 AM
2000redrocket
Score: 110
Status: offline
ok i take the two for everything ccause the elevator only has one servo. we were thinking two for the pressure on one rod at the edge but decided agenst it. you could do it with a Y harnes to hook two servos to one channel on the reciever like you do for flaps or alerons. just need to use the correct side of the servo crank so everything goes the same way. the sanding of the leading edge was scary on the amount of wood needing removed to feather the leading edge.
the larger fuel line we need cause we can not ritchen up the carb enough to make it not run correctly.so it must be borderline for enough fuel.
Hide Signatures
(in reply to gassprint1)
       Post #: 505
RE: Balsa USA enforcer - 5/24/2010 4:18 AM
gassprint1
Score: 100
Status: offline
I hear what you mean on the sanding. i'm going to just round the edje off and leave the ends flat a bit. some of the balsa is so paper thin, it's unreal. i added to the wing tips another 3/4 of an inch because of the sanding. looks much better than just the piece they say to use. by the time the tips are sanded you have only part of what you started with. as for the servo's, , i am going to put 2 servos in place of one? or am i going to run another rod to the other side which means i have 2 rods going to the elevator?...glad i have someone to talk to about it. don't reccomend the enforcer for a first build...
Hide Signatures
       Post #: 506
RE: Balsa USA enforcer - 5/24/2010 5:23 AM
2000redrocket
Score: 110
Status: offline
here is a picture of the enforcer matt and i made. it took two of us 3 weeks a couple of hours a night and a bunch on each weekend.
look at the white backers on the controle surfaces and you can see the rod going to the elevator just on one side for us.
here are some build shots
Hide Signatures
       Post #: 507
RE: Balsa USA enforcer - 5/25/2010 1:04 AM
oneaew@msn.com
Score: 122
Status: offline
i like the 2 servos in the elv oneon the other side like in your picture> will make it stronger elv> very nice looking plane you have allen
Hide Signatures
       Post #: 508
RE: Balsa USA enforcer - 5/25/2010 1:23 AM
2000redrocket
Score: 110
Status: offline
i think you are mistaken or i am not understanding you. there are only 3 servos back there. one for each surface. it works fine. the used enforcer had the servos up front with cables. that looked like a pain in the but plus they never felt solid like a wire link. it was eaiser for me to put then in the bottom of the wing. we made a 5 cell battery pack for the reciever from radioshack AA battery holders (one 4 cell and 1 single cell )and used that for balast way up front since there are two servoes missing.
also i agree on not haveing all the rear surfaces lined up perfect. we manual adjusted the elevator up some and the alerons down some to counteract and it flys nice. lands slow with all the wing area.
Hide Signatures
       Post #: 509
RE: Balsa USA enforcer - 5/25/2010 1:29 AM
oneaew@msn.com
Score: 122
Status: offline
yes i see the elv. servo i had another one there two across from each other> was a lot stronge for me then one> but if it works for you good>just thought i would let you know what i did> happf flying allen
Hide Signatures
       Post #: 510
RE: Balsa USA enforcer - 5/25/2010 1:32 AM
2000redrocket
Score: 110
Status: offline
cool. we thought about it but decided agenst the extra weight back there..
Hide Signatures
       Post #: 511
RE: Balsa USA enforcer - 5/25/2010 3:23 AM
gassprint1
Score: 100
Status: offline
putting the servos in the wing does make it look much cleaner as an install. i may just set it up that way also. i have heard of people putting retract in the wings also..very nice plane. hope mine looks that good when done..
Hide Signatures
       Post #: 512
RE: Balsa USA enforcer - 5/25/2010 3:52 AM
2000redrocket
Score: 110
Status: offline
i my self did not like the cable idea. tieing the alerons to one cable with the pushpull in the middle at the servo looked too much of a pain.
Hide Signatures
       Post #: 513
RE: Balsa USA enforcer - 5/25/2010 4:07 AM
oneaew@msn.com
Score: 122
Status: offline
my servos are 11 inches from the trailing edge 2 for elv. one on each ail. one for throttle> one for nose geaar> i have a 12 oz tank> os 61 eng>it flys just great> i had one with a ducted fan on it> but somehow the ground jumped up and got it> uiam going to build another one for the ducted fan>i have a picture of it on my profile> allen
Hide Signatures
       Post #: 514
RE: Balsa USA enforcer - 5/25/2010 7:20 PM
gassprint1
Score: 100
Status: offline
got a good question for ya, the servo compartment where the instructions say the sheeting over laps, did you trim the sheeting flush with the inside of the compartment or does it really hang over? how do i get pics here so i can show the wing?
Hide Signatures
       Post #: 515
RE: Balsa USA enforcer - 5/25/2010 8:38 PM
oneaew@msn.com
Score: 122
Status: offline
i trimed the sheeting flush > go to 2000red rocket on this web site and see the frame work on his plane you might ask him how to get pictures on i dont know how> sorry allen
Hide Signatures
       Post #: 516
RE: Balsa USA enforcer - 5/25/2010 8:42 PM
oneaew@msn.com
Score: 122
Status: offline
hi can u tell me how to put pictures like yous on the site thanks allen
Hide Signatures
       Post #: 517
RE: Balsa USA enforcer - 5/26/2010 1:17 AM
2000redrocket
Score: 110
Status: offline
first you have to have the pictures on the web someware.or host them your self by a web server. i use facebook. then view the picture on the web and right click and hit properties. you have to copy the whole address the picture is at . then i start a new line and type this
[img] theen paste what you copied here after the img thing then end it with a [/img]
Hide Signatures
       Post #: 518
RE: Balsa USA enforcer - 5/26/2010 1:18 AM
2000redrocket
Score: 110
Status: offline
Hide Signatures
       Post #: 519
RE: Balsa USA enforcer - 5/26/2010 1:19 AM
2000redrocket
Score: 110
Status: offline
that picture was a test on righ clicking the photo and copying the address (url) and putting it between a [img] and a [/img]
Hide Signatures
       Post #: 520
RE: Balsa USA enforcer - 5/26/2010 1:23 AM
oneaew@msn.com
Score: 122
Status: offline
ok ill try it thanks> ill bet the plane looks fast out there mine does only about 80 allen
Hide Signatures
       Post #: 521
RE: Balsa USA enforcer - 5/26/2010 1:46 AM
2000redrocket
Score: 110
Status: offline
we have a thundertiger .92 and it does about 95mph on a gps stuffed inside the body. the problem is that the pusher choices suck and this big lower rev engine needs a lot of pitch to get any speed.
Hide Signatures
       Post #: 522
RE: Balsa USA enforcer - 5/26/2010 2:25 AM
oneaew@msn.com
Score: 122
Status: offline
so u cut off 6inches of the nose and mount the engine up front and really go>[lol]
Hide Signatures
       Post #: 523
RE: Balsa USA enforcer - 5/26/2010 2:27 AM
oneaew@msn.com
Score: 122
Status: offline
go to my gallery and see one of mine allen
Hide Signatures
       Post #: 524
RE: Balsa USA enforcer - 5/26/2010 4:02 AM
gassprint1
Score: 100
Status: offline
hope this worked. here is the wing. soon i'll do like you did and put the servos in the wings.
Hide Signatures
       Post #: 525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
