2.6 Extra and 40% Carden 330 maiden flights!
Tower Hobbies
Logged in as Guest
  Printable Version
Carden 35% Extra 260 - RTF
Seller:  jmiracle
Details:   $2,950.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> 2.6 Extra and 40% Carden 330 maiden flights!
Page: [1]
Login
2.6 Extra and 40% Carden 330 maiden flights! - 3/28/2004 3:08:14 PM
Leardriver
Status: offline
Well yesterday was a good day indeed....my 2.6 Extra flew as did my buddy Albert's Carden Extra 330 ! Aside from some mixing to be done on the 2.6 everything went extremely well. And as far as the Carden....wow! I was fortunate enough to get a little stick time on Albert's Carden and it is absolutley awesome. All I can say is that anyone who honestly thinks that Cardens weigh too much hasn't spent any time flying them cause at 39lbs (with Dalton Aviation pipes) this thing flies as light as kite. It actually "felt" as light, if not lighter, than my 2.6 did! And I can say that the vertical was just ridiculous....unlimited just doesn't quite describe it. I cannot wait to get my 40% Carden built!
As for my 2.6 all I can say is I am really happy. It flies very light and lands like a trainer! My only complaint could be the amount of elevator/aileron coupling the rudder has....but no worries. Overall everything went very well and I am very pleased. I just can't wait to get out and fly it again!
Oh yea, kudos to Desert Aircraft....both my DA100 and Albert's DA150 are brand new and ran flawlessly!
All in all it was a great day !
Leardriver
       Post #: 1
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/28/2004 3:36:59 PM
RTK
Status: offline
Ldriver- What is your wt. and setup on your 2.6?
(in reply to Leardriver)
       Post #: 2
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/29/2004 2:14:48 AM
Leardriver
Status: offline
Well to be honest I was pretty upset about the weight......I DO NOT believe that these planes are 24lbs! I know several guys who have them and most are in the 26lb range. According to the "bathroom" scale my plane weighs 27lbs! I was pretty pissed when I saw that. Now I am runninga dual reciever setup and I made my own tray out of honey comb composite material (it weighed maybe 3-4oz more than the stock setup) to accomadate the bellcrank setup I opted for over what Comp-Arf supplies. So all together my rudder setup might weigh 6oz more than stock including the 4"SWB bellcrank and linkage.
Here is a complete rundown of my setup:
Comp-Arf 2.6 Extra House Scheme
DA10O w/ Slimline mufflers
B&B 32oz tank
8 Hitec 5945's
1 Futaba 9202's (throttle)
2 Futaba 149DP PCM recievers
2 Duralite Plus 2800mah packs (rx) w/6 volt regulators
1 Duralite Plus 1900mah pack (ignition) w/6 volt regulator
Hanger 9 wheel pants (off the Suhkoi...perfect paint match)
4" wheels...very light but I forget what make (Kavan maybe)
Graphtec tail wheel assembly
4 1/2" Truturn spinner
MSC 26x10 Prop (for break in purposes only...than Airmodels 25x12 3 bladed for IMAC)
Cermark heavy duty switches
Smart-fly equalizers for ailerons
Smart-Fly Ignition kill
4 Hanger 9 2" Titanium links for the ailerons
2 Hanger 9 2 1/2" Titanium links for the elevators
Dubro locking clevises all around
I am going to weigh it again cause I have a very hard time swollowing the fact that this thing is really 27lbs! It fly's very light but zi still want to know cause I really didn't add much weight to it at all.....8-10oz between the servo tray and the second reciever. I am also using Lithium batts are very light compared to nicad packs.
I will try to oast a pic tomorrow night.
Leardriver
Leardriver
< Message edited by Leardriver -- 3/29/2004 2:29:59 AM >
(in reply to RTK)
       Post #: 3
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/29/2004 4:16:36 AM
Shortman
Status: offline
Sounds good, why are you using Equalizers on the ailerons with Hitec servos? You can get the programmer and eliminate that.
_____________________________
Steven Carroll
AMA# 738035
       Post #: 4
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/29/2004 2:39:03 PM
walton
Status: offline
He is probally using it as a power buss to take some of the load off of the reciever.
(in reply to Shortman)
       Post #: 5
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/29/2004 7:46:59 PM
RobT
Status: offline
I belive the 27 lbs. A friend has one with Cans and Nimh batteries and with a digital scale fish scale we had it weight in at 28 lbs. She flies amazing. Feels light, and the DA just keeps pulling.
(in reply to walton)
       Post #: 6
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/29/2004 9:46:44 PM
Leardriver
Status: offline
Hey Guys,
Rob I don't doubt it...Comp-Arf's claim of 24lbs is a bit on the low side to say the least. I am sure that there are some out there that light, but I would put down paper that "most" are in the 25 1/2-27 lb range. I spose it doesn't matter because they all seem to fly very well once they are setup. So when is your Carden gonna beready man? Albert's flies soooo nice, I was just blown away. Out of the box it was just amazing! I gotta get him to get started on my fuse already! LOL!
Shortman, the reason I decided to go the Smart-Fly equalizer route was simple.......I don't own a programmer and just cannot see dropping $150 on one. Plus, the equalizers are a hell of a lot simpler and easier to setup than messing with the programmer. Yes I know the programmer is viable but imagine going to am IMAC event to find out you have a bad servo. Let's see...do I take 5 minutes to set up the equalizer or go looking to borrow a programmer from someone and spend considerably more time trying to figure it out. My buddy borrowed one and it just is not that simple and proved to be way more time consuming than I deemed it worth. And to be honest, I went the Hitec route cause I got a very nice deal on them. I am honestly not yet convinced and with things like the JR 8611 and Futaba 9152/9153 now avail it is going to hard to justify the expense of the programmer for the Hitec equipt.
I also want to sent out major Kudos to Bob from Smart-Fly. When I was setting up my plane I unfortunatley received a Smart-Fly 3D Equalizer that was defective (my luck), but not only did Smart-Fly send me out a new one they also "threw in" one of their "Bat-Share" units "for my trouble". I didn't even know that they did that until it showed up at my door. That was extremely thoughtful. Yes, good customer should always be expected, especially when you are dealing with a defective product, but I honestly thought this was going above and beyond and really made a satisfied customer out of me. Even though it was not an overly expensive item it really showed me that these guys care about the products they produce and the people that support them by buying them.
And just to clerify things...the Equalizer did not fail in the plane...it simply did not work out of the box. I don't think it is a common thing at all since we have a bunch of guys using em around here with good results. I also installed the ignition cut and it works flawlessly as well. So I will be very happy to support Smart-Fly/Quest Engineering by using their products again in the future and I encourage ou guys out there to give them a try. Ok...enough raving <g>.
Leardriver
(in reply to RobT)
       Post #: 7
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/30/2004 12:34:44 AM
Leardriver
Status: offline
Here are the pics I promised.......
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Leardriver -- 3/30/2004 12:57:55 AM >
       Post #: 8
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/30/2004 12:39:12 AM
Leardriver
Status: offline
ok...more.....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 9
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/30/2004 1:02:05 AM
RobT
Status: offline
No Cans? Are you flying it in IMAC?
       Post #: 10
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/30/2004 1:55:41 AM
Shortman
Status: offline
Very nice install.
Steven Carroll
AMA# 738035
(in reply to RobT)
       Post #: 11
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/30/2004 2:46:15 AM
Leardriver
Status: offline
Rob,
I did not go with cans. I really think that a 35% plan pays too high of a weight penalty with the addition of cans. Like you said, your buddy's plan was like 28lbs! I spoke with Jason Shulman before I decided on what exhaust to go with and he suggested the slimline mufflers. They seem to be a bit quieter than the stock DA's plus I have an Airmodels 25x12 3 bladed that I am gonna use for IMAC...it really is nice and quiet with this setup. Although my Carden will have cans, that's for sure. 150 has a bit more bark than the 100!
Now having said that...your Edge I saw you fly at the seminar was VERY quiet! I don't know what it actually weighs, but it looked like it flew nice and light. Is it an Aeroworks? How much wing area does it have...I believe the Comp-Arf is in the neighborhood of 1810sq inches which seems a little on the low side for a 100cc airframe. Albert said you have cans in it which would explain why it was so quiet.
Thanks for the complement Shortman.
Leardriver
       Post #: 12
RE: 2.6 Extra and 40% Carden 330 maiden flights! - 3/30/2004 2:57:45 AM
Flyfalcons
Status: offline
Considering how well these planes fly I wouldn't consider 1800 square inches too low for this plane.
Ryan Winslow
Cub flying - the new EXTREME SPORT!!! (evarrr)
